Successful case
- 1 Realtek RTD1296 Intelligent voice, video processing platform
- 2 5G + 4G LTE+Wifi AC+Gigabit Multiplex aggregate route
- 3 Sweet fume machine Intelligent sleep meter
- 4 4G LTE router design
- 5 DOJO smart home
- 6 Magic mirror
- 7 4G Multi-network fusion server
- 8 MultiQB Home multimedia gateway
- 9 KANO Pixel Kit
- 10 eBlocker
- 11 3G Information security terminal
- 12 4G Industrial safety tablets
- 13 MTK MT6737 4G watch
- 1. MediaTek MT7622,1.35GHZ 64 bit dual-core ARM Cortex-A53
- 2. (1-2)G DDR and 8G eMMC flash
- 3. 1x5G port , Use USB 3.0 or PCIe bus.
- 4. 4x4G LTE , support OpenMPTCProuter Multiple polymerization protocol.
- 5. 5xGigabit port. support VPN ,router function.
- 6. wifi 802.11 b/g/n/ac function support.
- 7. IoT expanding application
- 8. Base on Banana Pi BPI-R64 hardware design
moere,please see here:
Discuss on forum : http://forum.banana-pi.org/t/bpi-4-0-bpi-r64-for-5g-4g-lte-wifi-ac-gigabit-for-converged-communication-gateway/9555
use ESP32 design , suppor WiFi and BT to connect network.
more Spec ,please see :http://wiki.banana-pi.org/Sweet_fume_machine_Intelligent_sleep_meter_design
more Spec,please see : http://forum.banana-pi.org/t/bpi-4-0-4g-lte-router-design/9277
DOJO smart home
Dojo official webstie: https://dojo.bullguard.com/
Magic mirror
PCBA base on BPI-M3 with allwinner A83T chip design
forum discuss:http://forum.banana-pi.org/t/banana-pi-bpi-4-0-oem-odm-project-magic-mirror-base-bpi-m3-allwinner-a83t-chip-design/7410
this is base on BPI-R2, with 4 4G module desin. We can work with our customers to provide overall solutions
- Chassis design file : https://drive.google.com/file/d/1C9LuXVgexsUN3K8DqApFNG4FLpwn54Ms/view?usp=sharing
4G Multi-network fusion terminal
product website: https://www.aixiaocao.com/
OpenMPTCProuter
pcba inside:
Case design:
Hardware Specs
- SIZE: two-deck, 88x88 mm
- Memory: 1 GB DDR3
- USB: USB Host 2.0 x 1
- AUDIO Input: Microphone x 1
- VIDEO Outputs: HDMI out x 1
- IR Receiver: x1
KANO Pixel Kit
eBlocker
PCBA inside:
PCBA inside:
MTK MT6737 4G watch
4G watch PCBA:
4G watch Spec
Interface Configuration:
Software Configuration:
Necessary Accessories:
