Banana Pi BPI-F2S
Banana Pi BPI-F2S is the first board with Banana Pi team and SunPlus, this is a industrial-grade board. use Plus1(sp7021) design.
Application direction
- Smart Audio
- Smart Payment system
- FPGA education and development
about SunPlus SP7021
characteristics of the SP7021
- Easy-to-use LQFP package.
- Single 3.3V power*.
- 10-year supply guarantee.
- And much more...
note : 40 PIN GPIO compitable Raspberry Pi
Kit include
- 1. BPI-F2S sunplus board
- 2. FPGA baord: Xilinx Artix-7 XC7A100T,32 MByte QSPI Flash memory,power by single 3.3v
- 3. teaching sheet board : 4 digit 7 segment digital tube teaching,DIP8 socket for SPI flash IP authentication,8 LED lights are used for teaching
- 4. debug tooling
- 5. 12v/2A adapter
Key Features:
- Xilinx Artix-7 XC7A100T-2CSG324C
- 32 MByte Flash memory
- 95 I/O's (42 + 42 + 3 + 8)
- I2C EEPROM
- 7.3 x 3.5 cm form factor
- JTAG/UART connector
- One user LED
User manual:
Source code on github
Fedora-Mate
- FPGA TRM-TE0725LP-01_usermanual https://drive.google.com/file/d/1yKsbKSc2VSZgkFH_Oezm_75lD5un8MMT/view?usp=sharing
