Banana Pi BPI-F2S
Banana Pi BPI-F2S is the first board with Banana Pi team and SunPlus, this is a industrial-grade board. use Plus1(sp7021) design.
Application direction
- Industrial Internet control
- IoT
- FPGA education and development
about SunPlus sf7021
SunPlus sf7021 is a revolutionary SoC that has the power of a Linux-grade chip and the integration simplicity of a microcontroller.it with ARM Cortex-A7 Quad core,ARM926 real-time core,8051 low-power core
characteristics of the SP7021
- Easy-to-use LQFP package.
- Single 3.3V power*.
- 10-year supply guarantee.
- And much more...
FPGA extend board
Key Features:
- Xilinx Artix-7 XC7A100T-2CSG324C
- 32 MByte Flash memory
- 95 I/O's (42 + 42 + 3 + 8)
- I2C EEPROM
- 7.3 x 3.5 cm form factor
- JTAG/UART connector
- One user LED
- HyperRAM from Cypress cypress.com/products/hyperram-memory
- HyperFlash from Cypress cypress.com/products/hyperflash-nor-flash-memory
Source code on github
