Banana Pi BPI-F2S
Revision as of 04:52, 9 November 2019 by Sinovoip (talk | contribs) (Hardware)
File:Banana PI BPI-F2S 1.JPG
Banana Pi BPI-F2S
File:Banana PI BPI-F2S 4.JPG
sunplus SF7021 chip design
File:Banana PI BPI-F2S 5.JPG
Industrial operating
SunPlus SP7021 Diagram
Banana Pi BPI-F2S is the first board with Banana Pi team and SunPlus, this is a industrial-grade board. use Plus1(sp7021) design.
about SunPlus sf7021
SunPlus sf7021 is a revolutionary SoC that has the power of a Linux-grade chip and the integration simplicity of a microcontroller.it with ARM Cortex-A7 Quad core,ARM926 real-time core,8051 low-power core
characteristics of the SP7021
  • Easy-to-use LQFP package.
  • Single 3.3V power*.
  • 10-year supply guarantee.
  • And much more...
FPGA extend board
