BPI-Nano robot board
Revision as of 23:31, 9 October 2019 by Sinovoip (talk | contribs) (Sample code)
arduino Nano robot board
 BPI-Nano arduino Nano
BPI-UNO32 with ESP32
This robot board is design for Arduino Nano and Nano compatible boards. It is designed by Harsh Dethe and made by BPI factory.
BPI-Nano robot boards motor drive expansion plate available in the bpi-nano controller supports dual-circuit motor control, with single maximum current up to 1A.
Arduino standard pin design interface, also can be used with Arduino Nano.It can be applied to the development of small mobile robot.
Technical specifications
  • Driver chip: L293B
  • Logical working voltage: 5V DC
  • Motor drive voltage: 7-12v DC
  • Maximum driving current: 1A (per circuit)
  • Pin for motor drive: pin4/5/6/7 (Arduino controller)
  • Size: 56x57mm
PIN define
BPI-Nano aruino Nano robort GPIO pin define
Pin Function
Digital 2、4 Motor2 Steering control, 2 high level, 4 low level positive turn;Whereas inversion
Digital 3 Motor 2 Enable interface, high level enable
Digital 5 Motor 1 Enable interface, high level enable
Digital 7、8 Motor 1 Steering control, 7 high level, 8 low level positive turn;Whereas inversion
Sample code
//This motor shield use Pin 2,3,4,5,6,7,8 to control the motor
// Just plug the nano into the shield
// Simply connect your motors to M1 ,M2
// Upload the code to BPI-NANO/arduino
// Through serial monitor, type 'a','s', 'w','d','x' to control the motor
// http://www.banana-pi.org/
// Last modified on 20/09/2019
int EN1 = 5;  //Motor 1 Enable
int EN2 = 3;  //Motor 2 Enable
int IN1 = 7;
int IN2 = 8; //Motor 1
int IN3 = 2;
int IN4 = 4; //Motor 2
void Motor1(int ENA, boolean reverse)
         digitalWrite(ENA,HIGH);
        if(reverse)
         digitalWrite(IN1,HIGH);
         digitalWrite(IN2,LOW);
       else
         digitalWrite(IN1,LOW);
void Motor2(int ENB, boolean reverse)
         digitalWrite(ENB,HIGH);
        if(reverse)
         digitalWrite(IN3,HIGH);
         digitalWrite(IN4,LOW);
       else
         digitalWrite(IN3,LOW);
         digitalWrite(IN4,HIGH);
void setup()
   int i;
   for(i=2;i<=8;i++)  //For BPI-NANO Motor Shield
   pinMode(i, OUTPUT);  //set pin 2,3,4,5,6,78 to output mode
   Serial.begin(9600);
void loop()
 int x,delay_en;
 char val;
 while(1)
   val = Serial.read();
   if(val!=-1)
         switch(val)
            case 'w'://Move ahead
                       Motor1(100,true);
                       Motor2(100,true);
                        break;
            case 's'://move back
                       Motor1(100,false);
                       Motor2(100,false);
                        break;
            case 'a'://turn left
                       Motor1(100,true);
                       Motor2(100,false);
                        break;
            case 'd'://turn right
                       Motor1(100,false);
                       Motor2(100,true);
                       break;
              case 'x'://stop
                       digitalWrite(ENA,LOW);
                       digitalWrite(ENB,LOW);
                        break;
