Banana Pi BPI-R1
Revision as of 09:13, 19 September 2019 by Sinovoip (talk | contribs)
zn:香蕉派_BPI-R1
Overview:front
Overview:back
Getting Started with R1
  • 1 GB DDR3 memory.
  • 1x SATA interface.
Banana Pi R1
Memory 1GB DDR3
Network 10/100/1000 Ethernet 8P8C, Wi-Fi
Power Source 5 volt via Micro USB (DC in only) and / or Micro USB OTG
LED Power Key & 8P8C
Storage SATA 2.0
Compulsive modification of HDMI output resolution
3,compile sunxi-tools
cd sunxi-tools
make
4,backup script.bin
7,edit script.fex file:
nano script.fex
see this below:
[disp_init]
disp_init_enable = 1
disp_mode = 0
screen0_output_type = 3
screen0_output_mode = 5
screen1_output_type = 2
screen1_output_mode = 11
fb0_framebuffer_num = 2
fb0_format = 10
fb0_pixel_sequence = 0
fb0_scaler_mode_enable = 1
fb1_framebuffer_num = 2
fb1_format = 10
fb1_pixel_sequence = 0
fb1_scaler_mode_enable = 0
lcd0_backlight = 197
lcd1_backlight = 197
lcd0_bright = 50
lcd0_contrast = 50
lcd0_saturation = 57
lcd0_hue = 50
lcd1_bright = 50
lcd1_contrast = 50
lcd1_saturation = 57
lcd1_hue = 50
0 480i
1 576i
2 480p
3 576p
4 720p 50Hz
5 720p 60Hz
6 1080i 50 Hz
7 1080i 60 Hz
8 1080p 24 Hz
9 1080p 50 Hz
10 1080p 60 Hz
11 PAL
12 PAL SVIDEO
14 NTSC
15 NTSC SVIDEO
17 PAL_M
18 PAL_M SVIDEO
20 PAL_NC
21 PAL_NC SVIDEO
23 1080p 24 Hz 3D
24 720p 50 Hz 3D
25 720p 60 Hz 3D
26 1360x768 60 Hz
27 1280x1024 60 Hz
copy script.bin to /boot
9,reboot and make a try
sudo reboot
bootargs=enforcing=1 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootwait init=/init vmalloc=384M ion_c
ma_list="120m,176m,512m" loglevel=8 bootmenutimeout=10 datadev=mmcblk0p2 disp.screen0_output_type=3 disp.screen0_o
utput_mode=10 disp.screen1_output_type=3 disp.screen1_output_mode=10
How to build OpenWRT image from github
1,install depend package :
2,get openwrt source code
3,enter openwrt dir:
cd BPI-OpenWRT
4,update package and install
./scripts/feeds update -a
./scripts/feeds install -a
please choose your need:
example : i need web and add chinese support
LuCI—> 1. Collections  ---> <*> luci  add Luci support ,it mean web GUI support,it is defaultes
LuCI—>2. Modules  ---> <*> luci-i18n-chinese   add chinese also you can choose others.
make
8 running :
Stable 1.2.1 release:
Kernel upgraded to 4.1.17
Added Parted package
Lots of package upgrades and bug fixes...
VM build system - OpenwrtBuild-BPI-R1-VM-V1.0.torrent if you wish to spin up your own version from scratch!
github link: https://github.com/db260179/openwrt-bpi-r1
Officeal OpenWRT
BPI OpenWRT V4.0
  • BPI-R1_OpenWrt_V4.0
google drive: https://drive.google.com/file/d/0B3EGHv0FSPOGeHJNdmVXS3UtMUU/view?usp=sharing
baidu cloud: http://pan.baidu.com/s/1mg8Gjna
MD5: CB597EE79A6E27630AD7F903D23C4A7B
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-openwrt-4-0-new-image-release/430
Android 4.4
  • 2018-07-28 update android 4.4 HDMI version image
Features Map:http://wiki.banana-pi.org/R1_Image_Map
Baidu Drive:https://pan.baidu.com/s/1dorsPZAqCbL1oC6J4zQyvQ
Google Drive:https://drive.google.com/open?id=1ztI_dB0veEPkEaB7XV7OdEb3YE2mwywm
Ubuntu kernel 3.4
  • 2018-07-28 ubuntu-server-16.04
support BPI-R1
google drive :https://drive.google.com/open?id=1ztI_dB0veEPkEaB7XV7OdEb3YE2mwywm
baidu drive  :https://pan.baidu.com/s/1dorsPZAqCbL1oC6J4zQyvQ
Forum thread:
http://forum.banana-pi.org/t/bananapi-m1-m1p-r1-new-image-android-and-ubuntu-sever-release-2018-07-28/6357
  • 2016-07-21 update ubuntu-mate-16.04-desktop
support BPI-M2,BPI-M1+,BPI-R1
google drive : https://drive.google.com/file/d/0B_YnvHgh2rwjY0VlUGdobzFtdk0/view?usp=sharing
MD5: 155f072da499a7c523b7394f77dd9def
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-new-image-ubuntu-mate-16-04-desktop-armhf-raspberry-pi-bpi-m1-m1p-r1-sd-emmc-2016-07-21/2052
  • 2016-07-19 update, need use >=16G SD card
google drive : https://drive.google.com/file/d/0B_YnvHgh2rwjUXZmZTh3ZG5LTEU/view?usp=sharing
MD5: 37d6599eac4daced375fba8fa58dc1d5
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-new-image-edu-ubuntu-mate-1604-preview-bpi-m1-m1p-r1-img-2016-07-19/2043
  • 2016-07-10 update Ubuntu-16.04-xenial-minimal
google drive :https://drive.google.com/file/d/0B_YnvHgh2rwjUXFrU0ZDX3Z2NlE/view?usp=sharing
MD5: b900b9ba3b0f664a2cfae1fa1146b2fa
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-new-image-ubuntu-16-04-xenial-minimal-preview-bpi-m1-m1p-r1-img-2016-07-10/1991
  • 2016-06-04 update Ubuntu-16.04-xenial
google drive :https://drive.google.com/file/d/0B_YnvHgh2rwjQ1JJNkpQSXoxVVk/view?usp=sharing
baidu cloud:http://pan.baidu.com/s/1jHDZCsY
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-new-image-ubuntu-mate-16-04-xenial-preview-bpi-r1-sd-emmc-2016-06-04/1821
google driver:https://drive.google.com/file/d/1TAirzSDpbhtfznlxD6DL3HiCJ2c0FESB/view?usp=sharing
forum pthread:http://forum.banana-pi.org/t/bpi-m1-m1-r1-new-image-debian-10-buster-mate-desktop-with-grub-support-boot-2019-07-kernel-5-1-1/9916
Debian u-boot-2016.07, kernel 4.6.5
  • 2016-07-21 update
image name :2016-08-04-Armbian_5.17_Lamobo-r1_Debian_jessie_4.6.5_desktop-build-by-bpi-r1.img.zip
google drive download : https://drive.google.com/file/d/0B_YnvHgh2rwjV3I5RlpwdmZHYWs/view?usp=sharing
MD5: f6952fc265ba26c953eb929d23d1ac95
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-new-image-armbian-5-17-bpi-r1-debian-jessie-4-6-5-desktop-build-by-bpi-r1-img/2095
  • 2015-07-21 update Debian8_docker uboot : 2015-7 linux kernel: 4.2. 4
google drive download :https://drive.google.com/file/d/0B3EGHv0FSPOGSXVIaUVaRDBldE0/view
baidu cloud :http://pan.baidu.com/s/1kTnKNrx
MD5:0e3349ea78e790382461a538264b569d
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-new-image-debian8-docker-k4-2-beta-v4-0/516
Armbian image
Image lownload link :https://www.armbian.com/lamobo-r1/
Rasbian image
  • 2016-07-13 update raspbian jessie
google drive download : https://drive.google.com/file/d/0B_YnvHgh2rwjdTh5ZnVZam1rb0E/view?usp=sharing
MD5: 156b09907586ea9e86481bda73f4254f
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-new-image-raspbian-jessie-bpi-m1-m1p-r1-img-2016-07-13/2011
  • 2016-07-12 update raspbian lite
google drive download : https://drive.google.com/file/d/0B_YnvHgh2rwjRXRuWHJ5V3BJTmc/view?usp=sharing
MD5: 302063f7417079390da79334258dd538
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-new-image-raspbian-lite-bpi-m1-m1p-r1-img-2016-07-12/2004
Fedora
  • Banana pi BPI-R1 mainline linux kernel for fedora
https://www.wiesinger.com/opensource/fedora/kernel/BananaPi-R1/
Kanux
  • 2016-07-12 update KANO OS Beta 3.3.0 (support rpi3 rpi2 rpi1)
google drive download : https://drive.google.com/file/d/0B_YnvHgh2rwjaXQtVGUtbFplTUU/view?usp=sharing
MD5: 1951f3abc0a54675d9bbbac387760e4e
Forum thread:
http://forum.banana-pi.org/t/bpi-r1-new-image-kanux-beta-3-3-0-preview-bpi-m1-m1p-r1-img-2016-07-15/2025
Arch linux
  • Archlinux 28-12-2017 4.6.5 sunxi mainline kernel
Kernel borrowed from armbian: BPI-R1 new image:Armbian_5.17_bpi-r1_Debian_jessie_4.6.5_desktop-build-by-bpi-r1.img
Archlinux upgraded from official bpi image.
The kernel issues related to kernel / userspace mismatch seem to be gone (such as systemd-sysctl input / output error etc).
Image download link: http://mkaczanowski.com/files/archlinux-bpi-r1-2017-28-2017-4.6.5-sunxi-mainline.img
FreeBSD
  • Banana pi as the official partner of Allwinner , must banana pi product use Allwinner chip design . such as A20/A31S/H3/H2+/A64/A83T , and FreeBSD have support many Allwinner . so easy to use on banana pi board.
Allwinner A20 (sun7i), a dual-core Cortex-A7 : BPI-M1/BPI-M1+/BPI-R1
Allwinner A31 and A31s (sun6i), a quad-core Cortex-A7 : BPI-M2
Allwinner A64 sun50i), a quad-core Cortex-A53 :BPI-M64
Allwinner A83T (sun8i), an octa-core Cortex-A7 : BPI-M3
Allwinner H3 (sun8i), a quad-core Cortex-A7 : BPI-M2+/BPI-M2+ EDU/
Asterisk
Others
