香蕉派 BPI-M4
Revision as of 04:52, 16 September 2019 by Sinovoip (talk | contribs) (产品介绍)
产品介绍
Overview:Realtek RTD1395
PoE function support
M.2 and PCIE support
Banana Pi BPI-M4 4核64位开发板,采用RTD1395芯片设计 ,为banana pi 团队最新的Banana Pi BPI-M4具有与Raspberry Pi Model B 一样的尺寸,但搭载更强悍的Realtek RTD1395 SoC,并支援PoE网路线供电与M.2插槽等功能,使用上更具弹性。
Banana Pi BPI-M4搭载Realtek RTD1395 SoC,具有4个64bit的A53处理器核心,以及Mali-470 MP4绘图处理器,在记忆体部分具有1GB或2GB DDR4记忆体版本可供选择,储存装置除了可以选择8GB至64GB eMMC之外,也能透过micro SD插槽扩充256GB以下记忆卡。
BPI-M4 I/O接口则有支援1080p输出的HDMI端子、3.5mm音源输出端子、RJ-45有线网路端子(100Mbps)、WiFi 5(IEEE 802.11 b/g/n/ac)、蓝牙4.2、4组USB2.0端子、1组USB2.0 Type-C端子,以及相容于Raspberry Pi 的40 Pin Header,其中28Pin为相容UART、I2C、SPI、PWM的GPIO,其于为+5V、+3.3V、GND电源端子。比较特别的是BPI-M4还有1组M.2 Key E扩充插槽,支援PCIe 2.0与USB 2.0传输规范,能够扩充网路介面卡等设备。
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
开发
Getting Started with M4
硬件接口示意
Size & Weight 92x60mm, 48g
OS Android and Linux
GPIO 引脚定义
CON1-P02 DCIN
CON1-P03 I2C1_SDA GPIO-17
CON1-P04 DCIN
CON1-P05 I2C1_SCL GPIO-16
CON1-P07 PWM1 GPIO-21
CON1-P08 UR1_TX GPIO-9
CON1-P10 UR1_RX GPIO-8
CON1-P11 SDIO-D0 GPIO-42
CON1-P12 AIO_BCK GPIO-3
CON1-P13 SDIO-D1 GPIO-43
CON1-P15 SDIO-D2 GPIO-44
CON1-P16 UR1_RTS GPIO-11
CON1-P18 UR1_CTS GPIO-10
CON1-P19 GSPI-MOSI GPIO-31
CON1-P21 GSPI-MISO GPIO-18
CON1-P22 GPIO-47 GPIO-47
CON1-P23 GSPI-SCK GPIO-19
CON1-P24 GSPI-CS GPIO-20
CON1-P26 PWM2 GPIO-22
CON1-P27 SDIO-D3 GPIO-45
CON1-P28 PWM3 GPIO-23
CON1-P29 SDIO-CLK GPIO-41
CON1-P31 SDIO-CMD GPIO-40
CON1-P32 SPDIF GPIO-50
CON1-P33 AIO_CK GPIO-4
CON1-P35 AIO_LRCK GPIO-2
CON1-P36 GPIO-53 GPIO-53
CON1-P37 GPIO-34 GPIO-34
CON1-P38 AI_SD GPIO-5
CON1-P40 AO_SD GPIO-6
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
Source code on github: https://github.com/BPI-SINOVOIP/BPI-M4-bsp
documents
  • BPI-M4 schematic diagram:
google driver:https://drive.google.com/file/d/1A6pj8Y9Ru1_qfMapIdiQnMavEs5xzN5H/view?usp=sharing
Baidu cloud:https://pan.baidu.com/s/1mnn51dwBV5uxpNheBD4vJA pincode: t6cd
google driver: https://drive.google.com/file/d/1xK-DAjdjXiY7BgGcmq7x-aL5g6djznqT/view?usp=sharing
baidu cloud : 链接: https://pan.baidu.com/s/1bSZFMJ2lD_zuQru6Lf27RQ Pincode: 6pb8
  • 2019-6-25 update ,This release is for BPI-M4 which is based on rtd1395,Image is Android 8.1.0 with kernel 4.9.119.
Features Map:http://wiki.banana-pi.org/M4_Image_Map#Android_8.1_HDMI
Baidu Drive:https://pan.baidu.com/s/1KyTVmNX6LZtxqkRSQR9HMw (PinCode:9mwg)
Google Drive:https://drive.google.com/open?id=12wB3CqGBDxE7Cyi_BzZbAid0UlZCtcFZ
For detail steps please see here:http://wiki.banana-pi.org/Getting_Started_with_M4#Install_Android
Forum pthread:http://forum.banana-pi.org/t/bpi-m4-android-8-1-demo-image-release-2019-06-25/9401
Ubuntu linux
Debian linux
Google Drive : https://drive.google.com/open?id=1rVrZStsw2PINBhIxCzOLOtYLbtoECmEk
Baidu Drive : https://pan.baidu.com/s/1WcrBkxm5OyBLedCBwaUz6Q (PinCode:e6m3)
MD5 : 300b37cdfa092d72dceddd4f33825b40
Forum Pthread:http://forum.banana-pi.org/t/bpi-m4-bpi-w2-debian10-buster-desktop-new-demo-image-20190813/9712
Issue: if HDMI doesn’t display, please try “ctrl + alt + F1” to change terminal then “ctrl + alt + F7” change to desktop display.
SW2: switch to 0,if insert SD, SD start;if doesn’t insert SD,EMMC start.
Debian 10 buster (32bit)
Raspbian Linux
AArch Linux
Fetures Map:
  • AArch64 Linux Lite
Fetures Map:
