香蕉派 BPI-R2
BPI-R2概要
BPI-R2集成MTK7623N 四核 ARM Cortex-A7 MP 支持主频1.3 ghz,BPI-R2 路由器提供丰富各种外设接口,包括 HDMI TX 高清接口, MIPI DSI 屏接口, PCIe2.0 接口, USB2.0 OTG 端口, USB3.0 端口, SATA 端口,5 千兆网口, 板载802.11a/b/g/n wifi 无线& BT4.1蓝牙 , 并且通过mini PCI-e支持 802.11ac/n WLAN
BPI-R2 系统支持 Android5.1,并完善支持 OpenWRT,Debian linux,Ubuntu linux, Raspbian 和其他嵌入式操作系统. 尺寸与BPI-R1完全一样大小, 支持 1080P y高清视频输入,40 PIN GPIO 与 Raspberry Pi 3一致.
- Mali 450 MP4 GPU
- 2G DDR3 SDRAM
- Mini PCIE interface.
- support 2 SATA interface
开始使用
- 使用BPI-R2开发:快速上手 香蕉派 BPI-R2
- Frank 整理的Wiki文档,很详细的开发手册
硬件接口示意
Banana Pi BPI-R2 硬件规格 | |
CPU | MediaTek MT7623N, Quad-core ARM Cortex-A7 |
GPU | Mali 450 MP4 GPU |
Memory | 2G DDR3 SDRAM |
Storage | Onboard 8GB eMMC Flash, Micro SD-Card slot, Two SATA 2.0 Port |
Network | 5 x 10/100/1000 Mbit/s Ethernet (MT7530) |
WIFI&BT | Wi-Fi 802.11 b/g/n 2.4G/5G + Bluetooth BT4.1(MT6625L) |
Display(s) | HDMI (Type A) output with HDCP 1.4, resolutions up 1920x1200; MIPI Display Serial Interface (DSI) interface(4 data lanes) |
Video decoder(s) | Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc. H.264 high-profile 1080p@60fps, HEVC/H.265 1080P@60fps |
Audio Output(s) | HDMI & I2S |
USB port | USB 3.0 PORT (x2), USB OTG (x1) |
mini PCIE | 1 mini pcie interface & 1 pcie pin define interface |
Remote | IR Receiver (x1) |
LED | Power Status and 8P8C |
Size & Weight | 148 mm × 100.5mm 100g |
OS | OpenWRT, Debian, Ubuntu, Raspbian and others OS |
BPI-R2 GPIO 定义
Banana pi BPI-R2 40 PIN GPIO 定义:
Banana pi BPI-R2 40 PIN GPIO 定义 | |||
GPIO Pin Name | Default Function | ||
CON1-P01 | VCC-3V3 | ||
CON1-P02 | VCC-5V | ||
CON1-P03 | I2C\_SDA0 | GPIO75 | |
CON1-P04 | VCC-5V | ||
CON1-P05 | I2C\_SCL0 | GPIO76 | |
CON1-P06 | GND | ||
CON1-P07 | PWM-003 | GPIO206 | |
CON1-P08 | UTXD1 | GPIO80 | |
CON1-P09 | GND | ||
CON1-P10 | URXD0 | GPIO81 | |
CON1-P11 | URXD1 | GPIO80 | |
CON1-P12 | I2S0\_BCK | GPIO74 | |
CON1-P13 | UTXD0 | GPIO79 | |
CON1-P14 | GND | ||
CON1-P15 | PWM-002 | GPIO205 | |
CON1-P16 | URTS1 | GPIO25 | |
CON1-P17 | VCC-3V3 | ||
CON1-P18 | UCTS1 | GPIO24 | |
CON1-P19 | SPI0\_MO | GPIO56 | |
CON1-P20 | GND | ||
CON1-P21 | SPI0\_MI | GPIO55 | |
CON1-P22 | PCM\_CLK | GPIO18 | |
CON1-P23 | SPI0\_CK | GPIO54 | |
CON1-P24 | SPI0\_CSN | GPIO53 | |
CON1-P25 | GND | ||
CON1-P26 | PCM\_RX | GPIO20 | |
CON1-P27 | I2C\_SDA1 | GPIO57 | |
CON1-P28 | I2C\_SCL1 | GPIO58 | |
CON1-P29 | PCM\_RST | GPIO22 | |
CON1-P30 | GND | ||
CON1-P31 | SPDIF\_OUT | GPIO200 | |
CON1-P32 | PCM\_TX | GPIO21 | |
CON1-P33 | I2S0\_MCLK | GPIO126 | |
CON1-P34 | GND | ||
CON1-P35 | I2S0\_LRCK | GPIO73 | |
CON1-P36 | PCM\_SYNC | GPIO19 | |
CON1-P37 | SPDIF\_IN1 | GPIO202 | |
CON1-P38 | I2S0\_DATA\_IN | GPIO72 | |
CON1-P39 | GND | ||
CON1-P40 | I2S0\_DATA\_OUT | GPI049 |
MIPI DSI \(屏显示接口\)
MIPI DSI of Banana pi BPI-R2 | |||
CN6-P01 | VCC-3V3 | ||
CN6-P02 | VCC-5V | ||
CN6-P03 | VCC-3V3 | ||
CN6-P04 | VCC-5V | ||
CN6-P05 | GND | ||
CN6-P06 | VCC-5V | ||
CN6-P07 | GND | ||
CN6-P08 | VCC-5V | ||
CN6-P09 | NC | ||
CN6-P10 | GND | ||
CN6-P11 | NC | ||
CN6-P12 | DSI-D0N | ||
CN6-P13 | NC | ||
CN6-P14 | DSI-D0P | ||
CN6-P15 | DSI\_TE | GPIO84 | |
CN6-P16 | GND | ||
CN6-P17 | I2C\_SDA2 | GPIO77 | |
CN6-P18 | DSI-D1N | ||
CN6-P19 | I2C\_SCL2 | GPIO78 | |
CN6-P20 | DSI-D1P | ||
CN6-P21 | CTP-INT | GPIO23 | |
CN6-P22 | GND | ||
CN6-P23 | CTP-RST | GPIO236 | |
CN6-P24 | DSI-CKN | ||
CN6-P25 | GND | ||
CN6-P26 | DSI-CKP | ||
CN6-P27 | GPIO28 | ||
CN6-P28 | GND | ||
CN6-P29 | GPIO83 | ||
CN6-P30 | DSI-D2N | ||
CN6-P31 | GPIO204 | ||
CN6-P32 | DSI-D2P | ||
CN6-P33 | GND | ||
CN6-P34 | GND | ||
CN6-P35 | LCM\_BLPWM | GPIO203 | |
CN6-P36 | DSI-D3N | ||
CN6-P37 | GND | ||
CN6-P38 | DSI-D3P | ||
CN6-P39 | NC | ||
CN6-P40 | GND |
UART 串口定义:
Debug Uart of Banana pi BPI-R2 | |||
CON2 P03 | UTXD2 | ||
CON2P02 | URXD2 | ||
CON2P01 | GND |
资源
软件源代码
参考文当
- BPI-R2 原理图V1.2:BPI-R2 V1.2 hardware schematic diagram
- BPI-R2 原理图V1.1 :BPI-R2 V1.1 hardware schematic diagram
- DXF 结构文件 BPI-R2 DXF design file
- MTK MT7623N 芯片规格书
软件镜像
Ubuntu with kernel 4.4
Ubuntu with kernel 4.14
- Image Release
OpenWrt(LEDE)
- MD5SUM
- Image Release
OpenMPTCProuter
Centos 7
- Image Release
- Image Release
- Image Release
- release date :2018-06-17
- SD-Card images:
- Discuss on forum :
yocto Linux
MQLinux 19.02 beta
- update 2019-03-12,
- Main features:
- DNS Proxy/Cache
- DDNS
- VLAN Extension for WAN
- DHCP Server
- FTP Server
- PPPoE Server
- Samber Server
- Cloud Login
- Firewall
- IP-MAC Locking
- Port Mapping/DMZ/UPnP
- Diagnose Tools …
- Main features:
BPI-R2 相关项目
