Banana Pi BPI-R64
Revision as of 02:56, 26 August 2019 by Sinovoip (talk | contribs) (→FAQ)
Overview:banana Pi BPI-R64
File:BPI-R64 POE 1.jpg
MTK MT7622
  • 1G DDR3 SDRAM
  • MTK7615 4x4ac wifi (option)
  • support 1 SATA interface
  • (1) USB 3.0
  • POE function support
Hardware Revision
File:BPI-R64 interface 1.JPG
SDRAM 1 GB DDR3
SATA support 1 SATA interface
USB 1 USB 3.0 host
Buttons Reset button
IR onboard IR receiver
DC Power 12V/2A with DC in
Sizes 148 mm × 100.5mm
Weight 100g
PoE support
more PoE module spec
BPI-R64 GPIO Pin define
Release
