BPI-NANO arduino NANO board
Revision as of 21:27, 16 August 2019 by Sinovoip (talk | contribs) (电源)
The BPI-Nano is a Arduino Nano board, it is a small, complete, and breadboard-friendly board based on the ATmega328 (same Arduino Nano 3.0), It has more or less the same functionality of the Arduino Duemilanove. It lacks only a DC power jack, and works with a Mini-B USB cable instead of a standard one. The Nano was designed and is being produced by Gravitech.made by sinovoip
Main spec
  • ATmega328P @16 MHz.
  • 32 KB Flash.
  • 2 KB SRAM.
  • 1 KB EEPROM
Banana Pi BP-UNO
Microcontroller ATmega328P
Operating Voltage 5V
Input Voltage: (recommended) 7-12V
Input Voltage: (limits) 6-20V
Digital I/O Pins 14(包括6个PWM输出)
PWM PIN 6个
Analog Input Pins 6个
I/O output Max 20mA
3.3V output Max 50mA
Flash 32KB(ATmega328P)其中0.5KB被bootloader占用
SRAM 2KB(ATmega328P)
EEPROM 1KB(ATmega328P)
Clock Speed 16MHz
onboard LED 13
size same as arduino NANO
There is a self-restoring fuse on the bpi-uno that automatically disconnects the power supply when short-circuiting or overcurrent exceeds 500mA, thus protecting the USB port and bpi-uno of the computer. While most computer USB ports provide internal protection, this fuse provides additional protection.
Power
BPI-NANO can power with MicroUSB port,PH2.0 port and VIN port.
Power dependent pins are as follows:
  • PH2.0 port: can input 7-12V,It can be controlled by a power switch。
  • 5V:5V power PIN。when use USB power,direct output USB supplied 5V voltage;When using external power supply, output 5V voltage after voltage stabilization压。
  • 3V3:3.3V power output PIN。output Max is 50 mA。
  • VIN:Connect to external dc 5V power supply
  • REF:I/O reference voltage. Other devices can identify the development board I/O reference voltage through this pin。
Note:FT232RL will only work if it is powered through the USB port。
输入输出
BPI-NANO有14个数字输入输出引脚,可使用 pinMode()、digitalWrite() 和 digitalRead() 控制。
其中一些带有特殊功能,这些引脚如下:
  • Serial:0(RX)、1(TX),被用于接收和发送串口数据。这两个引脚通过连接到FT232来与计算机进行串口通信。
  • 外部中断:2、3,可以输入外部中断信号。中断有四种触发模式:低电平触发、电平改变触发、上升沿触发、下降沿触发。详情可以参考这里attachInterrupt()
  • PWM输出:BPI-NANO有6路PWM输出3、5、6、9、10、11。(对应函数 analogWrite()) 。
  • SPI:10(SS)、11(MOSI)、12(MISO)、13(SCK),可用于SPI通信。可以使用官方提供的SPI库操纵。
  • L13:13号引脚连接了一个LED,当引脚输出高电平时打开LED,当引脚输出低电平时关闭LED。
  • TWI:A4(SDA)、A5(SCL)和TWI接口,可用于TWI通信,兼容I²C通信。可以使用官方提供的Wire库操纵。
BPI-NANO 6个模拟输入引脚,可使用analogRead()读取模拟值。每个模拟输入都有10位分辨率(即1024个不同的值)。默认情况下,模拟输入电压范围为0~5V,可使用 AREF引脚和analogReference()函数设置其他参考电压。
相关引脚如下:
  • REF:模拟输入参考电压输入引脚。
  • Rst:复位端口。接低电平会使BPI-NANO复位,复位按键按下时,会使该端口接到低电平,从而让BPI-NANO复位。
指示灯(LED)
BPI-NANO带有4个LED指示灯,作用分别如下:
  • ON:电源指示灯。当BPI-NANO通电时,ON灯会点亮。
  • TX:串口发送指示灯。当使用USB连接到计算机且BPI-NANO向计算机传输数据时,TX灯会点亮。
  • RX:串口接收指示灯。当使用USB连接到计算机且BPI-NANO接收到计算机传来的数据时,RX灯会点亮。
  • L13:可编程控制指示灯。该LED通过特殊电路连接到BPI-NANO的13号引脚,当13号引脚为高电平或高阻态时,该LED 会点亮;低电平时,不会点亮。可以通过程序或者外部输入信号,控制该LED亮灭。
通信
BPI-NANO具备多种通信接口,可以和计算机、其他BPI-NANO或者其他控制器通信。
ATmega328 提供了UART TTL (5V)串口通信,其位于0 (RX) 和1 (TX)两个引脚上。NANO上的FT232会在计算机上模拟出一个USB串口,使得ATmega328 能和计算机通信。Arduino IDE提供了串口监视器,使用它可以收发简单文本数据。NANO上的RX\TX两个LED可以指示当前NANO的通信状态。
SoftwareSerial库可以将NANO的任意数字引脚模拟成串口,从而进行串口通信。
ATmega328也支持I2C (TWI)和SPI通信。Arduino IDE自带的Wire库,可用于驱动I2C总线,自带的SPI库,可用于SPI通信。
自动复位
一些开发板在上传程序前需要手动复位,而BPI-NANO的设计不需要如此,在BPI-NANO连接电脑后可以由程序控制其复位。在FT232上的DTR信号端,经过一个100nf 的电容,连接到ATmega328 的复位引脚。
当计算机发出DTR信号时(低电平),复位端将得到一个足够长的脉冲信号,从而复位ATmega328。在Arduino IDE中点击上传程序,在上传前即会触发复位,从而运行引导程序,完成程序上传。
Arduino 软件
开始Arduino IDE编程
可通过Arduino IDE对BPI-NANO编程。
在BPI-NANO使用ATmega328 芯片上,存储有bootloader程序,使得用户可以上传程序到开发板上,而不需要使用额外的编程器。这个上传程序的过程使用STK500协议完成。
你也可以不使用bootloader,通过ICSP接口连接编程器给BPI-UNO上传程序。
Arduino 驱动安装
  • 1,Windows10 :Windows10插上后会自动安装驱动
  • 2,Windows7 :
插上BPI-UNO后,系统会尝试自动安装驱动,如果安装失败,会显示,“未能成功安装驱动设备”,这时可以手动安装驱动:
在“我的电脑”右键,设备管理器,其他设备;在”未知设备”上面右键,并点击“更新驱动程序软件”:
选择第二项,“浏览计算机以查找驱动程序软件”;
点击浏览,选择驱动地址,也就是是你下载的ArduinoIDE中的driver所在路径:
安装过程中如果出现如下提示,选择“安装”:
系统提示成功安装驱动:
在设备管理器中,可以看到Arduino的COM口:
然后就可以在Arduino的IDE中找到COM口:
这样,就可以使用Arudino IDE进行编程了。
参考资源
  • 原理图下载 :
  • DXF结构文件:
