BPI NB-IoT Linaro 96Boars
1.NB-IoT module:
  • NB-IoT module:Quectel BC95-B5/8/20 or BC95-G
  • Model and Frequency band:
SIM card:
  • Micro SD SIM Slot
  • e-SIM optional(footprint reserved on the board)
  • Antenna: IPEX antenna connector
2,MCU:
Hardware inerface
Harware spec
HardwareSpecification of BPi BC95-LINARO
Soc STM32F103RBT6
CPU ARM 32-bit Cortex™-M3 CPU @72MHz
SDRAM size 20 KB
Flash size 128KB
Power 5V/2A via MicroUSB / 2PIN Battery Connector
Low-level peripherals 40 Pins Header \(2.0mm Pitch\), 32×GPIOs,Some of which can be used for specific functions including UART, I2C, SPI, PWM
On board Network Quectel BC95
On board SIM MicroSD SIM SloteSIM\(option\)
USB 1 USB 2.0 host
Buttons Reset button, User button
Leds 1 Power status Led and 5 other Leds
Sizes 60mm×30mm
Weight 10g
Dimensions
GPIO (CON1) define
40 PIN GPIO (CON1) define:
Software introduction
1 ,Lite OS brief Huawei
2,BC95 software brief:
Command format:
  • Searching network steps:
AT+NBAND?//QueryBand
AT+CFUN?//value :1
AT+CIMI//Query IMSI number
AT+CSQ/Query the signal strength
AT+NUESTATS//Query module status
AT+CGATT?//Back + CGATT: 1 indicates that the attachment is successful, with a delay of about 30s
AT+CEREG?//Search for network status, 1 for Internet, 2 for Network
AT+CSCON?//Query the connection status, 1 CONNECT, 0 IDLE
  • Manually configure network if fails to register network automatically:
AT+CFUN=1 AT+CIMI//Execute CFUN = 1, wait for 4 seconds to query IMSI, if it can be found that the card has been identified;If not, please check the card is inserted and confirm whether it is a USIM card.
AT+NBAND?//Query frequency band information.
AT+CEREG=1//Set to automatically register network registration status, when the module registered on the network, will report URC.**AT+CGDCONT=1,“IP”,“APN”**//The APN is configured locally \(or not configured\) for local access.
AT+COPS=1,2,"46000"**//Specify PLMN search, PLMN configuration.
AT+CSQ//Query signal strength.
AT+NUESTATS// Query module status
![](/assets/quectel 5.png)
Quecte BC95 datasheet (CN version) https://drive.google.com/file/d/0B4PAo2nW2KfnWnRVczZXV3lPZmc/view?usp=sharing
STM32F103(LD) datasheet.
Discuss on forum : http://forum.banana-pi.org/t/bpi-nb-iot-linaro-96boars-with-quecte-bc95-module-developent-board/3416/2
