Successful case
MT7623N for 4G router
A64 for smart home design
4 4G module board via USB interface
A83T Raid Nas design
R40 for vehicle license plate recognition
R40 for IoT gateway with Z-wave, zigbee,WiFI
A64 for IoT gateway design
A20 Multimedia routing gateway design
H3 for Network security information analysis instrument
A20 for Unmanned aerial vehicle (uav) flight control
T3 design for vehicle traveling data recorderl
File:BPI07402 poe 1.JPG
ESP32 for IoT :Sweet fume machine
5G + 4G LTE+Wifi AC+Gigabit Mutiplex aggregate route
  • 1. MediaTek MT7622,1.35GHZ 64 bit dual-core ARM Cortex-A53
  • 2. (1-2)G DDR and 8G eMMC flash
  • 3. 1x5G port , Use USB 3.0 or PCIe bus.
  • 4. 4x4G LTE , support OpenMPTCProuter Multiple polymerization protocol.
  • 5. 5xGigabit port. support VPN ,router function.
  • 6. wifi 802.11 b/g/n/ac function support.
  • 7. IoT expanding application
  • 8. Base on Banana Pi BPI-R64 hardware design
Discuss on forum : http://forum.banana-pi.org/t/bpi-4-0-bpi-r64-for-5g-4g-lte-wifi-ac-gigabit-for-converged-communication-gateway/9555
Sweet fume machine Intelligent sleep meter
use ESP32 design , suppor WiFi and BT to connect network.
more Spec ,please see :http://forum.banana-pi.org/t/bpi-4-0-esp32-for-iot-design-sweet-fume-machine-smart-home-product/7544
4G LTE router design
more Spec,please see : http://forum.banana-pi.org/t/bpi-4-0-4g-lte-router-design/9277
DOJO smart home
Dojo official webstie: https://dojo.bullguard.com/
Magic mirror
PCBA base on BPI-M3 with allwinner A83T chip design
forum discuss:http://forum.banana-pi.org/t/banana-pi-bpi-4-0-oem-odm-project-magic-mirror-base-bpi-m3-allwinner-a83t-chip-design/7410
4G Multi-network fusion server
this is base on BPI-R2, with 4 4G module desin. We can work with our customers to provide overall solutions
4G Multi-network fusion terminal
product website: https://www.aixiaocao.com/
OpenMPTCProuter
MultiQB Home multimedia gateway
what we do : hardware design, BSP software design, tooling design, quantity production, product certification
pcba inside:
Case design:
Hardware Specs
  • SIZE: two-deck, 88x88 mm
  • Memory: 1 GB DDR3
  • USB: USB Host 2.0 x 1
  • AUDIO Input: Microphone x 1
  • VIDEO Outputs: HDMI out x 1
  • IR Receiver: x1
  • easy to add zigbee, z-wave ,NB-IoT and other IoT function.
KANO Pixel Kit
what we do : hardware design, quantity production
eBlocker
What we do : hardware design, BSP software design, PCBA support, product certification
PCBA inside:
4G Industrial safety tablets
PCBA inside:
MTK MT6737 4G watch
4G watch PCBA:
4G watch Spec
Interface Configuration:
Software Configuration:
Necessary Accessories:
