Getting Started with W2
Overview Banana Pi BPI-W2
Read more: Banana Pi BPI-W2
Install Linux Image On W2
Install Image On SD Card On Windows
- Board SW4 switch to 1
- English:
1.Format SD card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#Format_your_SD_under_Windows_os
2.Install Image On SD Card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#how_to_write_Linux_image
- Chinese:
https://www.cnblogs.com/topbin/p/10882992.html
Install Image On SD Card On Ubuntu
1.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 2.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 3.After step 2, then you can insert your TF card into W2, and press power button setup W2.
Install Image On EMMC On Ubuntu
1.Prepare a sd which is installed ubuntu image, the Board SW4 switch to 1, let W2 boot from sd card. 2.Copy emmc image to udisk then plug in W2, then mount udisk. 3.After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc. 4.After success to install, power off W2, switch SW4 to 0, power on W2.
Load Android image on W2
Install On SD Card
Install On EMMC
1.Connect debug console between PC and BPI-W2, and Power off BPI-W2 2.Run “boot_recovery.exe” 1)Check LK option --> yes 2)Choose HW Setting File as “RTD1296_hwsetting_BOOT_4DDR4_4Gb_s1866.config” 3)Choose dvrboot.bin File as “dvrboot.exe.bin” 4)Click Write button
3.After you click the Write button, then power on BPI-W2, the software will begins to burn boot to BPI-W2 and waiting for response "OK"。
4.Close app and power off BPI-W2. 5.Format your Udisk first and then copy Android image to it.
6.Change the image name to install.img
7.Copy other files in the following to Udisk.
8.Plug the U-disk to BPI-W2 USB3.0 interface(the blue one)
9.Open a terminal software, here I use SecureCRT 8.0.
10.Press “Esc” key on your PC, and power on BPI-W2, then press “enter” key, you will get into uboot command line.
11.Input these commands
Realtek> usb start
Realtek> fatload usb 0:1 0x01b00000 bluecore.audio
Realtek> fatload usb 0:1 0x03000000 emmc.uImage
Realtek> fatload usb 0:1 0x02100000 rescue.emmc.dtb
Realtek> fatload usb 0:1 0x02200000 rescue.root.emmc.cpio.gz_pad.img
Realtek> boot all
12.Check HDMI status to 100%
1.Download this image: * Google: https://drive.google.com/open?id=1BkkLcuNryVgwIpcrpX50G9kpQEcsFiDp * Baidu: https://pan.baidu.com/s/1fPSu8TyylN9wRP300WNs6A PinCode:z0wx 2.Prepare a sd card which installed image. 3.Switch SW4 to 1, boot w2 from sd card. 4.Execute commands "cd / ","bpi-copy android7xxx.img", then this android image will be installed on Emmc 5.Switch Sw4 to 0, remove sd card, power on W2
GPIO
PWM Control
SATA
1. Mount dev on W2
- "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
- iperf3 -c [server]
- iperf3 -u -c [server]
- iperf3 -s
WiFi & BT
STA
network={
ssid="ssid"
psk="password"
priority=1
AP
Developing
Develop 4G module with W2
GPU
- glmark2 Score: 30
