Getting Started with M64
Revision as of 01:05, 29 June 2019 by Sinovoip (talk | contribs)
BPI-M64
Overview Banana Pi BPI-M64
Overview: BPI-M64 respbian linux
A64 Key Features
  • 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-A64
  • 2GB DDR3 SDRAM
  • 8G EMMC
  • 10/100/1000Mbps Ethernet
  • WiFi (AP6212) & Bluetooth
R18 Key Features
  • 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-R18
  • 2GB DDR3 SDRAM
  • 8G EMMC
 * Using your USB-Serial Connect debug console on M64
Load your first image on M64
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M64, and press power button setup M64
Load your first image on M64 EMMC
 * Run your M64 with TF card
 * Plug your USB disk in M2U
 * After M64 recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC
 * Then power off M64, take TF card out, power on M64
Update your image
  * After built bsp code, you could find "SD" directory in project, "cd SD" you could find the generated bootloader, rootfs
  * execute “bpi-tools”, to update your bpi tools;
  * execute “bpi-update -c bpi-m64.conf -d /dev/sdX”, to download new driver to update your image
  * execute “file *.tgz”, to check download files’ type is compressed data
  * execute “bpi-bootsel”, you will see the bootloader path, “/usr/lib/u-boot/bananapi/bpi-m64/u-boot-with-dtb-bpi-m64-720P-8k.img.gz”
  * execute “bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/u-boot-with-dtb-bpi-m64-720P-8k.img.gz”, to update your bootloader
  * reboot
How to build uboot & kernel
Install tools
Touch screen
LCD 7"
  • Find "BPI_A64_LCD7.img.gz"
  • Then execute "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/u-boot-with-dtb-bpi-m64-lcd7-8k.img.gz"
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M2U console:
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on A64
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
We use HDF5640 camara.
IR function
  • Execute "getevent"
  • Use your IR device to send information to A64
  • cd /usr/local/bin
WringPi
How to Update WiringPi
File System
