Getting Started with R2
Revision as of 10:57, 28 June 2019 by Sinovoip (talk | contribs)
Overview Banana Pi BPI-R2
Read more: Banana Pi BPI-R2
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • 1x Mini PCIE interface
  • 2x SATA interface
BPI-R2 SATA interface
  • Note:
Load your first image on R2
 * apt-get install pv
Update Your Ubuntu On SD Card
Ubuntu On Emmc
 1. If you want to install Ubuntu on EMMC, follow these steps:
 * Burn an image to sd card, and set up R64 with sd card.
 * Copy the image which name contains "xxx-emmc-xxx" to U disk.
 * mount U disk to R64, then use bpi-copy to burn image to Emmc.
   bpi-copy  <XXX.img.zip>
 * XXX.img.zip is ubuntu image we can get it from http://www.banana-pi.org/r2-download.html
 * power off
 * remove SD & power on
OpenWrt On SD & Emmc Steps
     you will find two images:
     * mtk-bpi-r2-EMMC.img
     * mtk-bpi-r2-SD.img
Network-Configuration
GPIO
PWM Control
  • cd /usr/local/bin
  • Execute "./g40.py" to test RPi.GPIO
Develop 4G module with R2
Gets more info from here:
Using 4G module with BananaPi
WiFi and Ap mode on R2 Ubuntu
STA
  • wmt_loader (ignore errors)
  • ip link set wlan0 up
network={
ssid="ssid"
psk="password"
priority=1
  • dhclient wlan0
AP mode
  • echo A >/dev/wmtWifi
interface=ap0
bridge=br0
ssid=test_r2
driver=nl80211
country_code=US
hw_mode=b
channel=1
max_num_sta=5
wpa=2
auth_algs=1
rsn_pairwise=CCMP
wpa_key_mgmt=WPA-PSK
wpa_passphrase=ledetest
logger_stdout=-1
logger_stdout_level=2
  • And a bridge
  • brctl addbr br0
  • brctl addif br0 ap0
  • brctl addif br wan
AP mode
1. Make a bash script
  • vim setup.sh
#!/bin/ash
wmt_loader &
sheep 3
sleep 5
echo A > /dev/wmtWifi &
sleep 5
hostapd -d hostapd.conf
2. Create your hostapd.conf
  • vim hostapd.conf
interface=ap0
bridge=br-lan
ssid=BPI_R2
driver=nl80211
country_code=CN
hw_mode=g
channel=1
max_num_sta=5
wpa=2
auth_algs=1
rsn_pairwise=CCMP
logger_stdout=-1
3. Make it run
  • ./setup.sh
  • vim /etc/rc.local
 cd /root/
 sleep 6
 ./setup.sh &
Make your own image
Reference Link
