Getting Started with W2
Revision as of 02:29, 27 May 2019 by JackZengWiki (talk | contribs) (Install On SD Card)
Overview: BPI-W2 Android 6.0
Read more: Banana Pi BPI-W2
  • Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
  • Using your USB-Serial Connect debug console on W2
Install Linux Image On W2
Install Image On SD Card On Windows
  • Board SW4 switch to 1
  • English:
 1.Format SD card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#Format_your_SD_under_Windows_os
 2.Install Image On SD Card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#how_to_write_Linux_image
  • Chinese:
 https://www.cnblogs.com/topbin/p/10882992.html
Install Image On SD Card On Ubuntu
 1.Install bpi-tools on your system
 * apt-get install pv
 2.After you download the image, insert your TF card into your Ubuntu
 3.After step 2, then you can insert your TF card into W2, and press power button setup W2.
Install Image On EMMC On Ubuntu
 1.Prepare a sd which is installed ubuntu image, the Board SW4 switch to 1, let W2 boot from sd card.
 2.Copy emmc image to udisk then plug in W2, then mount udisk.
 3.After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc.
 4.After success to install, power off W2, switch SW4 to 0, power on W2.
Load Android image on W2
Install On SD Card
Install On EMMC
 1.Format SD Card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#Format_your_SD_under_Windows_os
 2.
 1.Download this image:
 * Google: https://drive.google.com/open?id=1BkkLcuNryVgwIpcrpX50G9kpQEcsFiDp
 * Baidu: https://pan.baidu.com/s/1fPSu8TyylN9wRP300WNs6A PinCode:z0wx
 2.Prepare a sd card which installed image.
 3.Switch SW4 to 1, boot w2 from sd card.
 4.Execute commands "cd / ","bpi-copy android7xxx.img", then this android image will be installed on Emmc
 5.Switch Sw4 to 0, remove sd card, power on W2
GPIO
PWM Control
SATA
1. Mount dev on W2
  • "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
  • iperf3 -c [server]
  • iperf3 -u -c [server]
  • iperf3 -s
WiFi & BT
STA
  • ip link set wlan0 up
network={
ssid="ssid"
psk="password"
priority=1
  • dhclient wlan0
AP
Developing
Develop 4G module with W2
GPU
  • Execute "glmark2-es" to start OpenGL test
  • glmark2 Score: 30
Make your own image
