Getting Started with W2
Read more: Banana Pi BPI-W2
Install Linux Image On W2
Install On SD Card
1.You could download latest image from our forum 2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 4.After step 3, then you can insert your TF card into W2, and press power button setup W2.
Install On EMMC
Load your first Android image on W2
Install On SD Card
Install On EMMC
GPIO
PWM Control
SATA
1. Mount dev on W2
- "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
- iperf3 -c [server]
- iperf3 -u -c [server]
- iperf3 -s
WiFi & BT
STA
network={
ssid="ssid"
psk="password"
priority=1
AP
Developing
Develop 4G module with W2
GPU
- glmark2 Score: 30
