Getting Started with W2
Read more: Banana Pi BPI-W2
Load your first image on W2
1.You could download latest image from our forum 2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 4.After step 3, then you can insert your TF card into W2, and press power button setup W2.
GPIO
PWM Control
SATA
1. Mount dev on W2
- "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
- iperf3 -c [server]
- iperf3 -u -c [server]
- iperf3 -s
WiFi & BT
STA
AP
Developing
Develop 4G module with W2
GPU
- glmark2 Score: 30
