BPI-K210 RISC-V AIoT board
[hide]About BPI-K210
BPI-K210 is the first Banana Pi board with RISC-V chip design.An integrated artificial intelligence SOC chip solution that can accommodate neural network models, using a new risc-v instruction set for the field of artificial intelligence and edge computing. The main target market is the IoT and STEAM education market
- 64-bit RISC-V CPU Dual-Core, up to 400MHz
- IMAFDC (RV64GC) ISA extension
- Hardware FPU (Float Point Unit), Double Precision
- 32 KB I-Cache per core and 32 KB D-Cache per core
- 8MB On-Chip SRAM 128Kbit One-Time Programmable Memory (OTP) ,Read Only Memory (ROM)
- DMA
- Camera and screen interface
- WiFI and BT support
- JTAG, OpenOCD support
About Kendryte K210 chip
The Kendryte K210 is located in the SoC of the AI and IoT markets and is a very convenient MCU.
BPI-K210 hardware
BPI-K210 interface
BPI-K210 Spec
Hardware spec | |||
CPU | Kendryte K210 64-bit RISC-V CPU Dual-Core, up to 400MHz | ||
ROM | 128Kbit | ||
SRAM | 8MB On-Chip SRAM 128Kbit One-Time Programmable Memory (OTP) | ||
Flash | SPI flash 128Mbit | ||
Display | LCD display interface | ||
Camera | 1 Camera interface | ||
Voice | 1 Head set,1 Speaker,1 Mic port | ||
Power | 5V@1A micro USB poweror or lithium battery power | ||
GPIO | 26 PIN GPIO | ||
Debug | JTAG debug interface | ||
Wi-Fi | TW-03 WiFI module onboard | ||
LEDs | 1 Power LED and 1 state LED | ||
Sizes | 68mm\*53mm |
BPI-K210 GPIO PIN define
BPI-K210 software
Source code on github
- K210 chip datasheet(English):https://drive.google.com/file/d/1AavU-bCoyA2BWSDB3NQBp41A7CvdJvBL/view?usp=sharing
- K210 chip datasheet(Chinese):https://drive.google.com/file/d/1_xQ3waq4ENHIlfJ7ujrfRSAClNAk6beL/view?usp=sharing
- K210 SDK(drive)、documents、compiler、OpenOCD Debugging software :https://kendryte.com/downloads/
- jacklab K210 wiki page : http://wiki.jackslab.org/K210
