BPI-K210 RISC-V AIoT board
Revision as of 18:17, 27 April 2019 by Sinovoip (talk | contribs) (BPI-K210 Spec)
Overview:BPI-K210
BPI-K210 AIoT
BPI-K210 RISC-V 64bit design
About BPI-K210
BPI-K210 is the first Banana Pi board with RISC-V chip design.An integrated artificial intelligence SOC chip solution that can accommodate neural network models, using a new risc-v instruction set for the field of artificial intelligence and edge computing. The main target market is the IoT and STEAM education market
  • 8MB On-Chip SRAM 128Kbit One-Time Programmable Memory (OTP) ,Read Only Memory (ROM)
  • DMA
  • Camera and screen interface
  • WiFI and BT support
  • JTAG, OpenOCD support
About Kendryte K210 chip
BPI-K210 hardware
BPI-K210 interface
BPI-K210 Spec
CPU Kendryte K210 64-bit RISC-V CPU Dual-Core, up to 400MHz
ROM 448KB
SRAM 8MB On-Chip SRAM 128Kbit One-Time Programmable Memory (OTP)
Flash 4MB(Onboard),A maximum of 4 Flash/SRAM, each Flash maximum 16MB
Power 5V@1AmicroUSBpoweror 5.5mm 12VDCport
GPIO 12-bits SAR ADC 18 channel, 2\*8-bit D/A converter, 4*SPI, 2*I2S, 2*I2C, 3*UART, Host SD/eMMC/SDIO, Slave SDIO/SPI
Wi-Fi 802.11 b/g/n/e/i 802.11 n\(2.4GHz 150Mbps\) 802.11 e\(Quality of Service\)
Bluetooth BT4.2 & BLE
Buzzer Passive buzzer
LEDs RGB LED/POWER LED/Receive LED/Transmit LED
Sizes 68mm\*53mm
BPI-K210 GPIO PIN define
BPI-K210 software
Source code on github
