Banana Pi Series Comparison
Revision as of 09:51, 25 February 2019 by Sinovoip (talk | contribs)
Banana Pi Single board computer Comparison
module Banana Pi BPI-M1 Banana Pi BPI-M1+ Banana Pi BPI-M2+ Banana Pi BPI-ZERO Banana Pi BPI-P2 Zero Banana Pi BPI-M2M Banana Pi BPI-M2 Berry Banana Pi BPI-M2U Banana Pi BPI-M3 Banana Pi BPI-M64 Banana Pi BPI-M4 Banana Pi BPI-S64 Core Banana Pi BPI-F2
Allwinner A20
Allwnner A20
Awinner H3/H2+/H5
Allwinner H2+ same size as RPI Zero W
Allwinner H2+ PoE
Allwinner R16/A33
Allwinner R40/V40 same size as RPI 3
Allwinner R40/V40
Allwinner A83T
Allwinner A64
File:Banana pi BPI-M4 1.JPG
Realtek RTD1395
BPI-S64 Core Actions S700
BPI-F2 with freescale IMX6
in progress
CPU A20,32 Bit Cortex™-A7 Dual-Core A20,32 Bit Cortex™-A7 Dual-Core H3,32 Bit Cortex™-A7 Quad-Core H2+,32 Bit Cortex™-A7 Quad-Core H2+,32 Bit Cortex™-A7 Quad-Core A33/R16,32 Bit Cortex™-A7 Quad-Core R40/V40,32 Bit Cortex™-A7 Quad-Core R40/V40,32 Bit Cortex™-A7 Quad-Core A83T,32 Bit Cortex™-A7  Octa-Core A64, 64 Bit Cortex A53 Quad Core Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit Actions SOC S700,ARM Cortex-A53 Quad-Core CPU freescale IMX6 ARM Cortex-A9 MPCore 4xCPU processor(with TrustZone)
GPU ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 PowerVR SGX544MP2 GPU ARM® Mali400MP2 Mali 470 MP4 GPU Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5 OpenGL ES 2.0 3D graphics accelerator with forshaders,2D graphics accelerator,and didicated OpenVG 1.1 accelerator
Memory \(SDRAM\) 1G (shared with GPU) 1G (shared with GPU) 1G (shared with GPU) 512M(shared with GPU) 512M(shared with GPU) 512(shared with GPU) 1G (shared with GPU) 2G (shared with GPU) 2G (shared with GPU) 2G (shared with GPU) 1G DDR4(option 2G) 2GB LPDDR3 2GB LPDDR3
Onboard Storage SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC MicroSD(TF) card /MMC card slot eMMC 8GB MicroSD(TF) card /MMC card slot MicroSD(TF) card /MMC card slot eMMC 8GB(option) MicroSD(TF) card /MMC card slot eMMC 8GB(option) MicroSD (TF) card / MMC card slot  eMMC 8GB SATA 2.0 port via USB MicroSD (TF) card / MMC card slot eMMC 8GB MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC eMMC 8GB MicroSD (TF) card / MMC card slot ,eMMC 8GB,PCIE interface eMMC8GB MicroSD (TF) card / MMC card slot ,eMMC 8GB,SATA interface
Network 10/100/1000 Ethernet 10/100/1000 Ethernet 10/100/1000 Ethernet NOPE 100M Ethernet NOPE 10/100/1000 Ethernet 10/100/1000 Ethernet 10/100/1000 Ethernet 10/100/1000 Ethernet 10/100 Ethernet Kit:10/100/1000 Ethernet 10/100/1000 Mbit/s Ethernet
Onboard WIFI &BT NOPE 802.11b/g/n 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 RTL8821 module withWi-Fi 802.11 b/g/n/AC Kit:802.11b/g/n & BT4.0 N/A
Display HDMI, CVBS , LVDS/RGB HDMI, CVBS , LVDS/RGB HDMI mini HDMI mini HDMI MIPI/LVDS HDMI, MIPI HDMI, MIPI HDMI, MIPI HDMI, MIPI HDMI Kit: HDMI MIPI LVDS HDMI out, LVDS out
Camera Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface MIPI Camera serial Interface(CSI) Parallel 8-bit camera interface NA Kit: DVP camera ;MIPI camera 1 * DVP camera interface and 1* MIP camera interface
Video Outputs HDMI 1.4@1920*1080P LVDS/Sync RGB/CPU LCD interface up to 1920x1200 Video decoding speed up to 1080p@60fps Video encoding H.264 HP up to 1080p@30fps HDMI 1.4@1920*1080P LVDS/Sync RGB/CPU LCD interface up to 1920x1200 Video decoding speed up to 1080p@60fps Video encoding H.264 HP up to 1080p@30fps HDMI 1.4 1080p@60fps Support H.265 decode by 4K@30fps, support H.264 video encoding up to 1080p@30fps HDMI 1.4 1080p@60fps,Support H.264 video encoding up to 1080p@30fps HDMI 1.4 1080p@60fps,Support H.264 video encoding up to 1080p@30fps Decoding up to 1920x1080@60fps H.264 HP video encoding up to 1920x1080@60fps HDMI 1.4 1080p@60fps MIPI LCD interface up to 1920x1080 Decoding up to 1920x1080@60fps Video encoding H.264 HP: speed up 1920x1080@30fps HDMI 1.4 1080p@60fps MIPI LCD interface up to 1920x1080 Decoding up to 1920x1080@60fps Video encoding H.264 HP: speed up 1920x1080@30fps HDMI 1.4 HEVC/H.265 decoder(SW), Main profile, 1080p@30fps H.264 video encoding up to 1080p@60fps, 720p@120fps HDMI 1.4 Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,H.265 decode up to 4KP30 1080P H.264 H.265 2K/4K support Real-time vide decode of most popular vide formats ,such as MPEG-4,H.264,H.265. support video encoder for baseline H.264 HDMI out, LVDS out
Audio Output 3.5 mm Jack and HDMI 3.5 mm Jack and HDMI HDMI mini HDMI mini HDMI 4ohm/2.5W Speaker(2 Pin Hole) 3.5 mm Jack and HDMI 3.5 mm Jack and HDMI 3.5 mm Jack and HDMI 3.5 mm Jack and HDMI 3.5mm Jack and HDMI Kit: 3.5mm Jack and HDMI 1 * 3.5 headset jack,HDMI
Audino In Microphone Microphone NOPE Microphone Microphone Microphone Microphone Microphone Microphone Microphone Microphone kit:Microphone Microphone
GPIO 26-PIN: GPIO, UART, I²C bus, SPI bus with two chip selects, CAN bus,PWM,+3.3 V, +5 V, ground 40-PIN: GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground Kit: 26-PIN GPIO, UART, I²C bus, SPI bus with two chip selects, PWM,+3.3 V, +5 V, ground 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. CAN bus
Remote IR reciever IR reciever IR reciever NOPE NOPE NOPE IR reciever IR reciever IR reciever IR reciever NA Kit: IR N/A
USB 2.0 Ports 2 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB por 1 USB 2.0 OTG 1 USB 2.0 OTG 1 USB 2.0 ports, 1 OTG microUSB port 4 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB port 4 USB 2.0 ports, 1 TYPE C Kit:1 USB ports, 1 OTG microUSB port 2 * USB 2.0 1* USB Otg
Buttons Reset button, Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Kit: Reset button, Power button, ADC button Power & Reset
LED Power LED (red), RJ45 LED (blue), user define LED (green) Power LED (red), RJ45 LED (blue), user define LED (green) Power LED (red,Can be defined by user) Power led Status led Power led Status led User define LED (red/power, blue, green) User define LED (red/power, blue, green) User define LED (red/power, blue, green) User define LED (red/power, blue, green) User define LED (red/power, blue, green) ower Status and Activity status Kit: User define LED (red/power, blue, green) 3* RGB leds
Power 5V/2A via MicroUSB and/or MicroUSB (OTG) 5V/2A via MicroUSB and/or MicroUSB (OTG) 5V/2A via DC in and/or MicroUSB (OTG) 5V/2A via MicroUSB 5V/2A via MicroUSB and PoE power 5V/2A via DC in and/or MicroUSB (OTG) 5V/2Avia MicroUSB and/or MicroUSB (OTG) 5V/2A via DC in and/or MicroUSB (OTG) 5V/2A via DC in and/or MicroUSB (OTG) 5V/2A via DC in and/or MicroUSB (OTG) 5V/2A with TYPE C or PoE Kit:DC 5V/2A 12V/2A with DC port
Board Size 92mm×60mm 92mm×60mm 65mm×65mm 65mm×30mm 65mmX52.5mm 51mm×51mm 85mm x 55mm 92mm×60mm 92mm×60mm 92mm×60mm 92mm×60mm 67.5 x 30 mm
  • All banana pi:
