5 Get the city weather
The development of preparation
- 1. First, ensure the integrity of the current firmware dependency package
help(“modules”)
- The effect is shown below. If you do not have two dependency packages on the diagram, please burn the latest firmware.
- Make sure you're connected to the Internet. if not , please see 2 WiFI wireless connection
Prepare the weather API
- 1 I'm using the national weather service API here, http://www.weather.com.cn/data/cityinfo/101200801.html # 101200801 (In jingzhou city),See details of city ids:http://mobile.weather.com.cn/js/citylist.xml
- 2. Request to return Json data sample
"weatherinfo":
"city": "jingzhou",
"cityid": "101200801",
"img1": "n7.gif",
"img2": "d2.gif",
"ptime": "18:00",
"temp1": "16℃",
"temp2": "23℃",
"weather": "Rain turns shade"
We can analyze these json files and write an example like this
example analyse
import urequests from microbit import * def get_weather(): url = "http://www.weather.com.cn/data/cityinfo/101200801.html" rsp = urequests.get(url) data = eval(rsp.text) # eval function is used to convert string type json data from -> to python dictionary type weather = data["weatherinfo"] L = weather["temp1"] #lowest temperature H = weather["temp2"] #the highest temperature return "L:" + L[:-1] + " H:" + H[:-1] #Data sample-> L:16 H:23 display.scroll(get_weather()) # L[:-1] H[:-1]Remove ℃ ℉ and two special symbol, can appear otherwise coding errors
Write at end
These operations are all performed in mpfshell. If you use Pycharm programming, you can also operate in mpfshell tools. I believe you should all be able to operate.
