Banana Pi BPI-M4
Revision as of 04:17, 13 February 2019 by Sinovoip (talk | contribs)
File:Banana pi BPI-M4 1.JPG
File:Banana Pi BPI-M4 3.JPG
Overview:Realtek RTD1395
PoE function support
  • Mali 470 MP4 GPU OpenGL ES 1.1/2.0
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
Video Output(s) 1080p capable HDMI port and multi-channel audio output (NO H./X.265 capabilities)
Size & Weight 92x60mm, 48g
OS Android and Linux
