Banana Pi BPI-M4
Revision as of 04:04, 13 February 2019 by Sinovoip (talk | contribs) (→Hardware spec)
  • Mali 470 MP4 GPU OpenGL ES 1.1/2.0
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
Video Output(s) 1080p capable HDMI port and multi-channel audio output (NO H./X.265 capabilities)
Power Source 5 volt @2A via Micro USB (TYPE C)
Size & Weight 92x60mm, 48g
OS Android and Linux
