Getting Started with BPI-W2
Read more: Banana Pi BPI-W2
Load your first image on W2
Build your own image on W2
How to make and run the 64-bit ubuntu 16.04 on SD card 2018-4-28=
PDF format file download
http://forum.banana-pi.org/uploads/default/original/2X/c/c6dc409abc249c57a4cb2b7aedaddec6b80a9026.pdf
Ubuntu 16.04 Install and run Node.js and http-server
  • insltall Node.js
   1.  apt-get install nodejs
   2.  apt-get install npm
   3.  npm install -g http-server
   4. make a link to nodejs:  cd /usr/bin/; ln -sf nodejs node
OpenWrt
Burn OpenWRT with Linux kernel 4.4 2018-4-25
1.About this release
2.Burn OpenWRT on W2 steps:
  • MP_Tool
  • RTD1296_hwsetting_BOOT_4DDR4_4Gb_s1866.config(hardware configuration file)
  • dvrboot.exe.bin(u-boot binary file)
![image|690x363](upload://crRvVBQa1rh3AkwaIPCgyoC3tIu.jpg)
  • Set your console parameters
  • Choose config file and uboot file
  • Choose "LK option"
  • Click Wirte button and then power on W2, and waiting for response "OK"
  • hypertrm
  • RTD1296_hwsetting_BOOT_4DDR4_4Gb_s1866_padding.bin(hardware configuration binary file)
  • Run hypertrm ,config console parameters right
  • Holding on press “ctrl + q” and power on board,after the screen show “d/g/r”,then loose “ctrl + q”
  • Input “h”,use Y-modem way to send “RTD1296_hwsetting_BOOT_4DDR4_4Gb_s1866_padding.bin” to W2 board
  • After finish transferred,input these parameters:
 s98007058
  01500000
  • Input “d”,and send u-boot binary file
  • after finish transferred,input “g” to burn u-boot file on W2 EMMC
  • U disk
  • install.img
2)Burn OpenWRT on W2 steps:
  • Format U disk as FAT32 filesystem
  • Copy install.img to U disk root directory
  • Decompress install.img to get four files:
  emmc.uImage
  bluecore.audio
  rescue.emmc.dtb
  • Plug U disk to W2 USB3.0 interface,holding press “Esc” button to power on W2 board
  • Then W2 board will go into u-boot console
  • Input these commands step by step:
  setenv bootargs "earlycon=uart8250,mmio32,0x98007800 console=ttyS0,115200 loglevel=7
  init=/etc/init root=/dev/mmcblk0p1 rootfstype=squashfs rootwait"
  save
  go ru
  • Waiting for OpenWRT burning,after finished,W2 will reboot and go into OpenWRT system.
![image|589x279](upload://hUzUJgkSzb2aoG1dF4WVVJG4o0A.jpg)
3.Image & Tools link:
Baidu Drive: https://pan.baidu.com/s/1Rs9F46wNJibORaeCfVh4wg PinCode:1w4w
4.BPI-W2 run OpenWRT video:
https://youtu.be/eTaRy8Jnfpk
GPIO
PWM Control
Develop 4G module with W2
WiFi and Ap mode on W2
AP mode
Make your own image
