Getting Started with R64
Read more: Banana Pi BPI-R64
- 1G DDR3 SDRAM
- MTK7615 4x4ac wifi on board
- Support 1 SATA interface
- 1 Port USB 3.0
- POE function support
* Prepare 8G/above TF card, USB-Serial interface, Ubuntu System * Using your USB-Serial Connect debug console on R64
Load your first image on R64
1.You could download latest image from our forum * Here is the example image link: 2.Install bpi-tools on your Ubuntu * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card 4.After step 3, then you can insert your TF card into R64, and press power button to setup R64
Ubuntu On Emmc
1. If you want to install image on EMMC, follow these steps: * Burn an image to sd card, and set up R64 with sd card. * Copy the image which name contains "xxx-emmc-xxx" to U disk. * mount U disk to R64, then use bpi-copy to burn image to Emmc.
bpi-copy <XXX.img.zip>
* After this, reboot R64. * Remove SD & power on.
Network-Configuration
GPIO
PWM Control
Sata
PCIe
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On R64 console:
BT & BLE on R64
R64 BT Architectural
- BT on R64
- BLE on R64
- MW_GAP name 7622_BT /*rename bt device*/
- MW_GAP info /*check local BT device info*/
- MW_GATTC scan /* start ble scan*/
- MW_GATTC stop_scan /* stop ble scan*/
WiFi and Ap mode on R64
- wmt_loader (ignore errors)
AP mode
- echo A >/dev/wmtWifi
- And a bridge
- brctl addbr br0
- brctl addif br0 ap0
- brctl addif br wan
