Getting Started with R64
Revision as of 01:29, 7 December 2018 by JackZengWiki (talk | contribs) (FAQ)
Read more: Banana Pi BPI-R64
  • 1G DDR3 SDRAM
  • Built-in 4x4n 802.11n/Bluetooth 5.0 system-on-chip
  • MTK7615 4x4ac wifi on board
  • Support 1 SATA interface
  • 1 Port USB 3.0
  • POE function support
 * Using your USB-Serial Connect debug console on R64
Load your first image on R64
 * apt-get install pv
 4.After step 3, then you can insert your TF card into R64, and press power button to setup R64
Ubuntu On Emmc
 1. If you want to install image on EMMC, follow these steps:
 * Burn an image to sd card, and set up R64 with sd card.
 * Copy the image which name contains "xxx-emmc-xxx" to U disk.
 * mount U disk to R64, then use bpi-copy to burn image to Emmc.
   bpi-copy  <XXX.img.zip>
 * After this, reboot R64.
 * Remove SD & power on.
Network-Configuration
GPIO
  • echo 431(22+409) > /sys/class/gpio/export
  • echo out > /sys/class/gpio/gpio431/direction
  • echo 1 > /sys/class/gpio/gpio431/value
PWM Control
Sata
  • Test a TOSHIBA HDD DISK, the Read/Write performance are below:
Read from disk: 50MB/s command: dd if=/dev/sda of=/dev/null bs=1M count=1024
Write to disk: 38MB/s command: dd if=/dev/zero of=/dev/sda bs=1M count=1024
Read from disk: 360MB/s command: dd if=/dev/sda of=/dev/null bs=1M count=1024
Write to disk: 200MB/s command: dd if=/dev/zero of=/dev/sda bs=1M count=1024
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On R64 console:
WiFi and Ap mode on R2 Ubuntu
  • wmt_loader (ignore errors)
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
AP mode
  • echo A >/dev/wmtWifi
 interface=ap0
 bridge=br0
 ssid=test_r2
 driver=nl80211
 country_code=US
 hw_mode=b
 channel=1
 max_num_sta=5
 wpa=2
 auth_algs=1
 rsn_pairwise=CCMP
 wpa_key_mgmt=WPA-PSK
 wpa_passphrase=ledetest
 logger_stdout=-1
 logger_stdout_level=2
  • And a bridge
  • brctl addbr br0
  • brctl addif br0 ap0
  • brctl addif br wan
Make your own image
Reference Link
http://forum.banana-pi.org/
