Banana Pi BPI-M2M
  • Allwinner R16/A33 Quad Core ARM Cortex A7 CPU.
  • 512MB DDR3 SDRAM.
  • 8G eMMC flash
  • CSI camera interface
  • DSI display interface
Banana Pi M2 Magic
CPU Allwinner R16 ARM Cortex-A7 Quad-Core
Memory 512MB LPDDR3 (shared with GPU)
Storage On Board 8GB eMMC Flash, Micro SD-Card slot.
Network Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0
Video Output(s) MIPI Display Serial Interface (DSI) for raw LCD Panel
Audio Output(s) 3.5mm jack
USB ports USB 2.0 PORT (x1), USB OTG (x1)
Remote Not IR Receiver
LED Power Status and 8P8C
Size & Weight 51x51mm, 48g
OS Android and Linux
40 PIN GPIO of Banana pi BPI-M2 Magic
PIN number Default Function Function2:GPIO
CON1-P02 DCIN
CON1-P03 TWI1-SDA PH5
CON1-P04 DCIN
CON1-P05 TWI1-SCK PH4
CON1-P07 PWM1 PH1
CON1-P08 UART2-TX PB0
CON1-P10 UART2-RX PB1
CON1-P11 UART3\_TX PH6
CON1-P12 UART2-CTS PB3
CON1-P13 UART3\_RX PH7
CON1-P15 AP-PCM-DOUT PG12
CON1-P16 UART2-RTS PB2
CON1-P18 AP-PCM-CLK PG11
CON1-P19 SPI0\_MOSI PC0
CON1-P21 SPI0\_MISO PC1
CON1-P22 AP-PCM-SYNC PG10
CON1-P23 SPI0\_CLK PC2
CON1-P24 SPI0\_CS PC3
CON1-P26 AP-PCM-DIN PG13
CON1-P27 LVDS\_V0N PD19
CON1-P28 PL11-EINT11 PL11
CON1-P29 LVDS\_V0P PD18
CON1-P31 LVDS\_V1N PD21
CON1-P32 LVDS\_V2N PD23
CON1-P33 LVDS\_V1P PD20
CON1-P35 LVDS\_VCN PD25
CON1-P36 LVDS\_V2P PD22
CON1-P37 LVDS\_VCP PD24
CON1-P38 LVDS\_V3N PD27
CON1-P40 LVDS\_V3P PD26
    • CSI Camera Connector specification:**
    • CSI Pin Name**
**Default Function** | **Function2:GPIO** | :--- | :--- | NC | | GND | | CSI0-SDA | PE13 | CSI0-AVDD | | CSI0-SCK | PE12 | CSI0-Reset | PE14 | CSI0-VSYNC | PE3 | CSI0-PWDN | PE15 | CSI0-HSYNC | PE2 | CSI0-DVDD | | CSI0-DOVDD | | CSI0-D7 | PE11 | CSI0-MCLK | PE1 | CSI0-D6 | PE10 | GND | | CSI0-D5 | PE9 | CSI0-PCLK | PE0 | CSI0-D4 | PE8 | CSI0-D0 | PE4 | CSI0-D3 | PE7 | CSI0-D1 | PE5 | CSI0-D2 | PE6 | GND | | CSI0-AFVCC | |
    • Display specification**
    • DSI Pin Name**
**Default Function** | **Function2:GPIO** | :--- | :--- | DSI-D0N | | DSI-D0P | | DSI-D1N | | DSI-D1P | | DSI-CKN | | DSI-CKP | | DSI-D2N | | DSI-D2P | | DSI-D3N | | DSI-D3P | | NC | | NC | | TP-SDA | PH3 | TP-SCK | PH2 | TP-INT | PB5 | TP-RST | PB6 | LCD-BL-EN | PL4 | LCD-RST | PL5 | LCD-PWR-EN | PB7 | LCD-PWM | PH0 | GND | | GND | | PS | | PS | |
    • UART specification:
GND | | :--- | :--- | UART0-RX | | UART0-TX | |
Opnewrt
TinaLinux
Release
