Banana Pi BPI-M2M
[hide]Introduction
- Allwinner R16/A33 Quad Core ARM Cortex A7 CPU.
- 512MB DDR3 SDRAM.
- 8G eMMC flash
- CSI camera interface
- DSI display interface
Banana Pi M2 Magic | |
CPU | Allwinner R16 ARM Cortex-A7 Quad-Core |
GPU | PowerVR SGX544MP1 Comply with OpenGL ES 2.0 OpenCL 1x, DX9_3 |
Memory | 512MB LPDDR3 (shared with GPU) |
Storage | On Board 8GB eMMC Flash, Micro SD-Card slot. |
Network | Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0 |
Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
Video Output(s) | MIPI Display Serial Interface (DSI) for raw LCD Panel |
Audio Input(s) | On board microphone |
Audio Output(s) | 3.5mm jack |
USB ports | USB 2.0 PORT (x1), USB OTG (x1) |
Remote | Not IR Receiver |
Switches | Reset, Power and U-boot |
LED | Power Status and 8P8C |
Size & Weight | 51x51mm, 48g |
OS | Android and Linux |
| | **Default Function** | **Function2:GPIO** | | :--- | :--- | :--- | | CON1-P01 | VCC-3V3 | | | CON1-P02 | DCIN | | | CON1-P03 | TWI1-SDA | PH5 | | CON1-P04 | DCIN | | | CON1-P05 | TWI1-SCK | PH4 | | CON1-P06 | GND | | | CON1-P07 | PWM1 | PH1 | | CON1-P08 | UART2-TX | PB0 | | CON1-P09 | GND | | | CON1-P10 | UART2-RX | PB1 | | CON1-P11 | UART3\_TX | PH6 | | CON1-P12 | UART2-CTS | PB3 | | CON1-P13 | UART3\_RX | PH7 | | CON1-P14 | GND | | | CON1-P15 | AP-PCM-DOUT | PG12 | | CON1-P16 | UART2-RTS | PB2 | | CON1-P17 | VCC-3V3 | | | CON1-P18 | AP-PCM-CLK | PG11 | | CON1-P19 | SPI0\_MOSI | PC0 | | CON1-P20 | GND | | | CON1-P21 | SPI0\_MISO | PC1 | | CON1-P22 | AP-PCM-SYNC | PG10 | | CON1-P23 | SPI0\_CLK | PC2 | | CON1-P24 | SPI0\_CS | PC3 | | CON1-P25 | GND | | | CON1-P26 | AP-PCM-DIN | PG13 | | CON1-P27 | LVDS\_V0N | PD19 | | CON1-P28 | PL11-EINT11 | PL11 | | CON1-P29 | LVDS\_V0P | PD18 | | CON1-P30 | GND | | | CON1-P31 | LVDS\_V1N | PD21 | | CON1-P32 | LVDS\_V2N | PD23 | | CON1-P33 | LVDS\_V1P | PD20 | | CON1-P34 | GND | | | CON1-P35 | LVDS\_VCN | PD25 | | CON1-P36 | LVDS\_V2P | PD22 | | CON1-P37 | LVDS\_VCP | PD24 | | CON1-P38 | LVDS\_V3N | PD27 | | CON1-P39 | GND | | | CON1-P40 | LVDS\_V3P | PD26 |
- CSI Camera Connector specification:**
- CSI Pin Name**
| | **Default Function** | **Function2:GPIO** | | :--- | :--- | :--- | | CN3-P01 | NC | | | CN3-P02 | GND | | | CN3-P03 | CSI0-SDA | PE13 | | CN3-P04 | CSI0-AVDD | | | CN3-P05 | CSI0-SCK | PE12 | | CN3-P06 | CSI0-Reset | PE14 | | CN3-P07 | CSI0-VSYNC | PE3 | | CN3-P08 | CSI0-PWDN | PE15 | | CN3-P09 | CSI0-HSYNC | PE2 | | CN3-P10 | CSI0-DVDD | | | CN3-P11 | CSI0-DOVDD | | | CN3-P12 | CSI0-D7 | PE11 | | CN3-P13 | CSI0-MCLK | PE1 | | CN3-P14 | CSI0-D6 | PE10 | | CN3-P15 | GND | | | CN3-P16 | CSI0-D5 | PE9 | | CN3-P17 | CSI0-PCLK | PE0 | | CN3-P18 | CSI0-D4 | PE8 | | CN3-P19 | CSI0-D0 | PE4 | | CN3-P20 | CSI0-D3 | PE7 | | CN3-P21 | CSI0-D1 | PE5 | | CN3-P22 | CSI0-D2 | PE6 | | CN3-P23 | GND | | | CN3-P24 | CSI0-AFVCC | |
- Display specification**
- DSI Pin Name**
| | **Default Function** | **Function2:GPIO** | | :--- | :--- | :--- | | CN2-P01 | DSI-D0N | | | CN2-P02 | DSI-D0P | | | CN2-P03 | DSI-D1N | | | CN2-P04 | DSI-D1P | | | CN2-P05 | DSI-CKN | | | CN2-P06 | DSI-CKP | | | CN2-P07 | DSI-D2N | | | CN2-P08 | DSI-D2P | | | CN2-P09 | DSI-D3N | | | CN2-P10 | DSI-D3P | | | CN2-P11 | NC | | | CN2-P12 | NC | | | CN2-P13 | TP-SDA | PH3 | | CN2-P14 | TP-SCK | PH2 | | CN2-P15 | TP-INT | PB5 | | CN2-P16 | TP-RST | PB6 | | CN2-P17 | LCD-BL-EN | PL4 | | CN2-P18 | LCD-RST | PL5 | | CN2-P19 | LCD-PWR-EN | PB7 | | CN2-P20 | LCD-PWM | PH0 | | CN2-P21 | GND | | | CN2-P22 | GND | | | CN2-P23 | PS | | | CN2-P24 | PS | |
- UART specification:
| CON3-P1 | GND | | | :--- | :--- | :--- | | CON3-P2 | UART0-RX | | | CON3-P3 | UART0-TX | |
Opnewrt
TinaLinux
