Banana Pi BPI-M64
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
- Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
- 2 GB DDR3 SDRAM
- 8G EMMC
- 10/100/1000Mbps Ethernet
- WiFi (AP6212) & Bluetooth
| Banana Pi M64 | |
| CPU | Allwinner A64 64 bit Quad Core ARM Cortex A53 1.2 GHz CPU |
| GPU | Dual core Mali 400 MP2 GPU |
| Memory | 2 GB LPDDR3 (shared with GPU) |
| Storage | MicroSD slot supports up to 256GB expansion & 8 G eMMC flash (option 16/32/64G) |
| Network | 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth BT4.0 |
| Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
| Video Output(s) | high-definition video playback & 2K HDMI port and multi-channel audio output (NO H./X.265 capabilities) |
| Audio Input(s) | On board microphone |
| Audio Output(s) | 3.5mm jack and HDMI |
| USB ports | USB 2.0 PORT (x2), USB OTG (x1) |
| Remote | IR Receiver (x1) |
| Switches | Reset, Power and U-boot |
| Size & Weight | 92x60mm, 48g |
| OS | Android and Linux |
| 40 PIN GPIO of Banana pi BPI-M64 | |||
| CON2-P01 | VCC-3V3 | ||
| CON2-P02 | VCC-5V | ||
| CON2-P03 | TWI1-SDA | PH3 | |
| CON2-P04 | VCC-5V | ||
| CON2-P05 | TWI1-SCK | PH2 | |
| CON2-P06 | GND | ||
| CON2-P07 | PH6 | PH6 | |
| CON2-P08 | UART2-TX | PB0 | |
| CON2-P09 | GND | ||
| CON2-P10 | UART2-RX | PB1 | |
| CON2-P11 | PH7 | PH7 | |
| CON2-P12 | UART2-CTS | PB3 | |
| CON2-P13 | DMIC-CLK | PH10 | |
| CON2-P14 | GND | ||
| CON2-P15 | DMIC-DIN | PH11 | |
| CON2-P16 | UART2-RTS | PB2 | |
| CON2-P17 | VCC-3V3 | ||
| CON2-P18 | PD4 | PD4 | |
| CON2-P19 | SPI1-MOSI | PD2 | UART4-TX |
| CON2-P20 | GND | ||
| CON2-P21 | SPI1-MISO | PD3 | UART4-RX |
| CON2-P22 | PC0 | PC0 | |
| CON2-P23 | SPI1-CLK | PD1 | UART3-RX |
| CON2-P24 | SPI1-CS | PD0 | UART3-TX |
| CON2-P25 | GND | ||
| CON2-P26 | PC2 | PC2 | |
| CON2-P27 | PC4 | PC4 | |
| CON2-P28 | PC3 | PC3 | |
| CON2-P29 | PC7 | PC7 | |
| CON2-P30 | GND | ||
| CON2-P31 | PCM0-BCLK | PB5 | |
| CON2-P32 | PCM0-DIN | PB7 | |
| CON2-P33 | PCM0-SYNC | PB4 | |
| CON2-P34 | GND | ||
| CON2-P35 | PCM0-DOUT | PB6 | |
| CON2-P36 | PL9 | PL9 | |
| CON2-P37 | PL12 | PL12 | |
| CON2-P38 | PL7 | PL7 | |
| CON2-P39 | GND | ||
| CON2-P40 | PL8 | PL8 | |
| CSI camer PIN define of Banana pi BPI-M64 | ||||||||||||||||||||||||||
| Default Function| Function2:GPIO| | -- | | NC| | GND| | CSI0-SDA| PE13| | CSI0-AVDD| | CSI0-SCK| PE12| | CSI0-Reset| PE16| | CSI0-VSYNC| PE3| | CSI0-PWDN| PE17| | CSI0-HSYNC| PE2| | CSI0-DVDD| | CSI0-DOVDD| | CSI0-D7| PE11| | CSI0-MCLK| PE1| | CSI0-D6| PE10| | GND| | CSI0-D5| PE9| | CSI0-PCLK| PE0| | CSI0-D4| PE8| | CSI0-D0| PE4| | CSI0-D3| PE7| | CSI0-D1| PE5| | CSI0-D2| PE6| | GND | | CSI0-AFVCC | |
| MIPI DSI display PIN define of Banana pi BPI-M64 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Default Function| Function2:GPIO| | -- | | VCC | | IPSOUT| | VCC | | IPSOUT| | GND| | IPSOUT | | GND | IPSOUT | | NC | | GND | NC | | DSI-D0N | NC | | DSI-D0P | NC | | GND | TWI0-SDA| PH1| | DSI-D1N | | TWI0-SCK| PH0| | DSI-D1P | CTP-INT| PH4| | GND| | CTP-RST| PH8| | DSI-CKN | | GND | DSI-CKP | | LCD-BL-EN| PD5| | GND | LCD-RST |PD6| | DSI-D2N | | LCD-PWR-EN |PD7| | DSI-D2P | | GND | GND | | LCD-PWM| PL10| | DSI-D3N | GND | DSI-D3P | | NC | GND | |||||||||||||
| Uart PIN define of Banana pi BPI-M2+ | ||||
| Default Function| GPIO| | -- | | UART0-TXD| PB8| | UART0-RXD| PB9| | GND | |
