Getting Started with M3
Revision as of 01:30, 9 November 2018 by JackZengWiki (talk | contribs) (WiFi Client)
BPI-M3
Overview: BPI-M3 respbian linux
Overview: BPI-M3 debian linux
Overview: BPI-M3 ubuntu linux
  • Octa-core 1.8GHz Powerful CPU
  • 2 GB LPDDR3 memory
  • 8 GB eMMC storage
  • WiFi & Bluetooth onboard
Development For Android
Load your first image on M3
 Ex: http://wiki.banana-pi.org/Banana_Pi_BPI-M3#Android_5.1.1_V5
Load your image on M3 EMMC
 1.The only different with sd card burning is the image burning mode item choice
 2.After succeed to burn image to SD, then plug SD card in your M3
 3.Press power button, device will copy image to EMMC automatically
How to buld M3 Bsp code
 * Prepare a PC which runs ubuntu
 * Install Docker-ce on your PC,https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-ce
 * After install Docker, execute "docker pull sinovoip/bpi-build:ubuntu12.04", to pull image
 * Then you pulled image, execute "docker run --privileged -d -p 2222:22 -v /media:/media sinovoip/bpi-build:ubuntu12.04"
 * "ssh -p 2222 [email protected] #default passwd is root"
 * Execute "git clone https://github.com/BPI-SINOVOIP/BPI-M3-bsp.git" on your ubuntu terminal
 * Execute "./build.sh" to build M3 bsp code
 * After built, open a new terminal, execute "docker cp xxxxx(your container id):xxxxx(your project path) xxxxx(your pc path)"
Development For Linux
 * Using your USB-Serial Connect debug console on M3
 * Here is the example link: http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-release-raspbian-jessie-8-0-2018-5-28-v1-1/5847
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M3, and press power button setup M3
 * Run your M3 with TF card
 * Plug your USB disk in M3
 * After M3 recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC
 * Then power off M3, take TF card out, power on M3
Update your image
  * execute “bpi-tools”, to update your bpi tools;
  * execute “bpi-update -c bpi-m3.conf”, to download new driver to update your image
  * execute “file *.tgz”, to check download files’ type is compressed data
  * execute “bpi-bootsel”, you will see the bootloader path, “/usr/lib/u-boot/bananapi/bpi-m3/BPI_M3_720P.img.gz”
  * execute “bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m3/BPI_M3_720P.img.gz”, to update your bootloader
  * reboot
Make your own image
Make one raspbian image
  • Prepare a SD card which have installed Raspbian system
  • Boot your SD card with M3, after M3 finish starting, copy your files and config your Raspbian, then poweroff M3
  • Execute "bpi-migrate -c bpi-m3.conf -c raspbian-jessie-from-sd.conf -d /dev/sdx"
Install Docker
You could try armbian to install docker, here is the image: https://dl.armbian.com/bananapim3/Debian_stretch_dev.7z (Here Thanks for the armbian community)
Download this image to your ubuntu PC (I am using ubuntu PC), then decompress it
  • 7z x Debian_stretch_xxx.img
  • bpi-copy Debian_stretch_xxx.img /dev/sd< drive letter >
 username: root, password: 1234
Here are steps to install docker:
  • vim /etc/apt/sources.list
  • apt-get update
  • apt-get install docker.io
SATA
1. Mount SATA on M3
  • "mount /dev/sdx /mnt/xxx"
OTG
1. On M3 console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M3 and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M3 OTG
  • If yes, we could execute "adb shell" to connect M3 by adb now
LCD 5" & LCD 7"
  • Find "BPI_M3_LCD7.img.gz"
  • Then execute "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-M3/BPI_M3_LCD7.img.gz"
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M3 console:
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on M3
  • ip link set wlan0 up
  • dhclient wlan0
Ov5640
Ov8865
  • "/test_ov8865.sh"
IR function
  • Execute "getevent"
  • Use your IR device to send information to M3
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
GPU
  • Execute "glmark2-es" to start OpenGL test
  • glmark2 Score: 258
File System
