BPI:bit robot expansion board
About BPI:bit robot extension board
BPI:bit robot extension board is a bpi-bit development board, which is mainly designed for smart cars and robots with bit as the core.At the same time, it also takes into account the ordinary IO extension function, which makes it convenient for users to use their imagination and create possibilities
BPI:bit robot extended board power supply:
The extended edition, there are two kinds of power-supply modes, 12V/2A dc power supply and Micro USB via 5V/2A power adapter power supply, the only use the extension board IO extension function instead of dc motor and servo motor, can use 5 v Micro USB for extended version of the power supply directly, but if you use the motor and steering gear, then you must use 12 v dc supply.
