Banana Pi BPI-ZERO
Revision as of 17:01, 7 May 2018 by Sinovoip (talk | contribs) (Getting Start)
  • 512MB DDR 3 SDRAM.
  • Mini HDMI.
Quick strart your BPI-M2 zero Quick Start Banana pi SBC
HardWare Specification of Banana pi BPI-M2 zero
CPU H2+ Quad-core Cortex-A7 H265/HEVC 1080P
GPU Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0
Memory \(SDRAM\) 512M \(shared with GPU\)
Onboard Storage TF card \(Max. 64GB\)
Onboard Network NOPE
Onboard WIFI SDIO AP6212(option AP6181、AP6335)
Video Input A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps
Video Outputs Supports Mini HDMI Port
Audio Output Mini HDMI
Power Source Micro USB with 5V/2A
USB 2.0 Ports one USB 2.0 OTG
Buttons Power Button, Reset Button
Low-level peripherals 40 Pins Header,compatible with Raspberry Pi 3
LED Power led & Status led
IR nope
Supported OS Android, Ubuntu, Debian, Rasberry Pi Image
Product size 65mm × 30mm
Weight 35g
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI0-SDA PA12-EINT12
CON2-P04 VCC-5V
CON2-P05 TWI0-SCK PA11-EINT11
CON2-P06 GND
CON2-P07 PWM1 PA6-EINT6
CON2-P09 GND
CON2-P11 UART2-RX PA1-EINT1
CON2-P13 UART2-TX PA0-EINT0
CON2-P14 GND
CON2-P15 UART2-CTS PA3-EINT3
CON2-P17 VCC-3V3
CON2-P18 PC4 PC4
CON2-P19 SPI0-MOSI PC0
CON2-P20 GND
CON2-P21 SPI0-MISO PC1
CON2-P22 UART2-RTS PA2-EINT2
CON2-P23 SPI0-CLK PC2
CON2-P24 SPI0-CS PC3
CON2-P25 GND
CON2-P26 PC7 PC7
CON2-P27 TWI1-SDA PA19-EINT19
CON2-P28 TWI1-SCK PA18-EINT18
CON2-P29 PA7-EINT7 PA7-EINT7
CON2-P30 GND
CON2-P31 PA8-EINT8 PA8-EINT8
CON2-P33 PA9-EINT9 PA9-EINT9
CON2-P34 GND
CON2-P39 GND
24 PIN CSI Camera connector of Banana pi BPI-R2
CN3-P01 NC
CN3-P02 GND
CN3-P03 CSI0-SDA PE13
CN3-P04 CSI0-AVDD
CN3-P05 CSI0-SCK PE12
CN3-P06 CSI0-Reset PE14
CN3-P07 CSI0-VSYNC PE3
CN3-P08 CSI0-PWDN PE15
CN3-P09 CSI0-HSYNC PE2
CN3-P10 CSI0-DVDD
CN3-P11 CSI0-DOVDD
CN3-P12 CSI0-D7 PE11
CN3-P13 CSI0-MCLK PE1
CN3-P14 CSI0-D6 PE10
CN3-P15 GND
CN3-P16 CSI0-D5 PE9
CN3-P17 CSI0-PCLK PE0
CN3-P18 CSI0-D4 PE8
CN3-P19 CSI0-D0 PE4
CN3-P20 CSI0-D3 PE7
CN3-P21 CSI0-D1 PE5
CN3-P22 CSI0-D2 PE6
CN3-P23 GND
CN3-P24 CSI0-DOVDD
jumper CON3 of Banana pi BPI-R2
CON3 P03 UART0-TXD PA4
CON3 P02 UART0-RXD PA5
CON3 P01 GND
Opnewrt
RetroPie
Ubuntu 16.04 mate desktop 2017-11-13
