快速上手 香蕉派 BPI-R1
Revision as of 04:55, 27 October 2018 by Sinovoip (talk | contribs) (Created page with "en:Getting_Started_with_R1 =Introduction= ==BPI-R1== thumb|Overview: BPI-R1 bananian linux The Banana Pi R1 is a router based Banana Pi runni...")
BPI-R1
  • Dual-core 1.0GHz CPU
  • 1 GB DDR3 memory
  • Mali-400 MP2 with Open GL ES 2.0/1.1
 * Using your USB-Serial Connect debug console on R1
Load your first image on R1
 * apt-get install pv
 4.After step 3, then you can insert your TF card into R1, and press power button setup R1
