快速上手 R1
Revision as of 20:21, 26 October 2018 by Sinovoip (talk | contribs)
BPI-R1
Overview: BPI-R1 bananian linux
  • Dual-core 1.0GHz CPU
  • 1 GB DDR3 memory
  • Mali-400 MP2 with Open GL ES 2.0/1.1
 * Using your USB-Serial Connect debug console on R1
Load your first image on R1
 * apt-get install pv
 4.After step 3, then you can insert your TF card into R1, and press power button setup R1
