香蕉派 BPI-M1+
Banana Pi BPI-M1+是一款开源硬件单板电脑,为BPI-M1经典版本增加了更多的连接性。
Banana PI BPI-M1+是一款高性能双核开源硬件单板计算机,Banana PI BPI-M1+是一款比树莓派 2B 更强悍的双核Android4.4与Linux产品。
Banana PI BPI-M1+兼容性强大,可以跑android系统,Debian linux,Ubuntu linux, Raspberry Pi系统 和 cubieboard 系统.
Banana PI BPI-M1+硬件:1Ghz ARM7双核处理器,1GB DDR3内存,千兆以太网口,板载SDIO接口的WIFI模块SATA Socket,流畅运行Android4.4。Banana PI BPI-M1+体积如信用卡大小,轻松运行《雷神之锤三:竞技场》这样的游戏,支持1080P高清视频输出,GPIO兼容Raspberry Pi 2并直接运行其ROM Image。
- 1 GB DDR3 memory.
- Wifi &BT support onboard
- 1x SATA interface.
- 1x Gigabit LAN
- 1x USB otg and 2x USB 2.0
- 1X MIC
- AV out
- HDMI out
- IR
- CSI camera interface
- DSI display interface
- 40 PIN gpio
- 3.7V lithium battery interface
开始使用
- 镜像烧录及快速开始使用 : 快速上手 Banana pi SBC]]
- 使用BPI-M1+ 开发: 快速上手 M1P
Banana Pi BPI-M1+ | |||
CPU | A20 ARM Cortex -A7 Dual-Core | ||
GPU | ARM Mali400MP2Complies with OpenGL ES 2.0/1.1 | ||
Memory | 1GB DDR3 | ||
Network | 10/100/1000 Ethernet | ||
wifi&BT | Wifi & BT 4.0 support onboard | ||
Video Input | A CSI input connector allows for the connection of a designed camera module | ||
Video Outputs | HDMI, CVBS, LVDS/RGB | ||
Audio Outputs | 3.5mm jack and HDMI | ||
Power Source | 5V/2A via Micro USB (DC in only) and / or Micro USB OTG | ||
USB 2.0 ports | 2(direct from Allwinner A20 chip) | ||
GPIO | GPIO, UART, I2C BUS, SPI BUS, WITH TWO CHIP SELECTS, CAN bus, ADC, PWM, +3.3V, +5V, GND | ||
LED | Power Key & 8P8C | ||
Storage | SATA 2.0 | ||
OS | Android 4.4, Android 4.2, Raspbian, Lubuntu, Open Suse, Debian |
40 PIN GPIO of Banana pi BPI-M1+ | |||
GPIO Pin Name | Default Function | Function2:GPIO | |
CON3-P01 | VCC-3V3 | ||
CON3-P02 | VCC-DC | ||
CON3-P03 | TWI2-SDA | PB21 | |
CON3-P04 | VCC-DC | ||
CON3-P05 | TWI2-SCK | PB20 | |
CON3-P06 | GND | ||
CON3-P07 | PWM1 | PI3 | |
CON3-P08 | UART3\_TX | PH0 | |
CON3-P09 | GND | ||
CON3-P10 | UART3\_RX | PH1 | |
CON3-P11 | UART2\_RX | PI19 | |
CON3-P12 | PH2 | PH2 | |
CON3-P13 | UART2\_TX | PI18 | |
CON3-P14 | GND | ||
CON3-P15 | UART2\_CTS | PI17 | |
CON3-P16 | CAN\_TX | PH20 | |
CON3-P17 | VCC-3V3 | ||
CON3-P18 | CAN\_RX | PH21 | |
CON3-P19 | SPI0\_MOSI | PI12 | |
CON3-P20 | GND | ||
CON3-P21 | SPI0\_MISO | PI13 | |
CON3-P22 | UART2\_RTS | PI16 | |
CON3-P23 | SPI0\_CLK | PI11 | |
CON3-P24 | SPI0\_CS0 | PI10 | |
CON3-P25 | GND | ||
CON3-P26 | SPI0\_CS1 | PI14 | |
CON3-P27 | TWI3-SDA | PI1 | |
CON3-P28 | TWI3-SCK | PI0 | |
CON3-P29 | I2S\_MCLK | PB5 | |
CON3-P30 | GND | ||
CON3-P31 | I2S\_BCLK | PB6 | |
CON3-P32 | I2S\_DI | PB12 | |
CON3-P33 | I2S\_LRCK | PB7 | |
CON3-P34 | GND | ||
CON3-P35 | I2S\_DO0 | PB8 | |
CON3-P36 | UART7\_RX | PI21 | |
CON3-P37 | IR0\_TX | PB3 | |
CON3-P38 | UART7\_TX | PI20 | |
CON3-P39 | GND | ||
CON3-P40 | SPDIF\_DO | PB13 |
CSI PIN of Banana pi BPI-M1+ | |||
CSI Pin Name | Default Function Pin name | Function2:GPIO | |
CON1 P01 | LINEINL | ||
CON1 P02 | LINEINR | ||
CON1 P03 | VCC-CSI | ||
CON1 P04 | ADC\_X1 | ||
CON1 P05 | GND | ||
CON1 P06 | ADC\_X2 | ||
CON1 P07 | FMINL | ||
CON1 P08 | ADC\_Y1 | ||
CON1 P09 | FMINR | ||
CON1 P10 | ADC\_Y2 | ||
CON1 P11 | GND | ||
CON1 P12 | CSI-FLASH | PH17 | |
CON1 P13 | LRADC0 | ||
CON1 P14 | TWI1-SDA | PB19 | |
CON1 P15 | LRADC1 | ||
CON1 P16 | TWI1-SCK | PB18 | |
CON1 P17 | CSI-D0 | PE4 | |
CON1 P18 | CSI0-STBY-EN | PH19 | |
CON1 P19 | CSI0-D1 | PE5 | |
CON1 P20 | CSI-PCLK | PE0 | |
CON1 P21 | CSI-D2 | PE6 | |
CON1 P22 | CSI0-PWR-EN | PH16 | |
CON1 P23 | CSI-D3 | PE7 | |
CON1 P24 | CSI0-MCLK | PE1 | |
CON1 P25 | CSI-D4 | PE8 | |
CON1 P26 | CSI0-RESET\# | PH14 | |
CON1 P27 | CSI-D5 | PE9 | |
CON1 P28 | CSI-VSYNC | PE3 | |
CON1 P29 | CSI-D6 | PE10 | |
CON1 P30 | CSI-HSYNC | PE2 | |
CON1 P31 | CSI-D7 | PE11 | |
CON1 P32 | CSI1-STBY-EN | PH18 | |
CON1 P33 | AP-RESET\# | ||
CON1 P34 | CSI1-RESET\# | PH13 | |
CON1 P35 | CSI-IO0 | PH11 | |
CON1 P36 | HPR | ||
CON1 P37 | HPL | ||
CON1 P38 | IPSOUT | ||
CON1 P39 | GND | ||
CON1 P40 | IPSOUT |
LVDS PIN of Banana pi BPI-M1+ | |||
LVDS Pin | Default Function | Function2 | Function3:GPIO |
CON2 P01 | IPSOUT\(5V output\) | ||
CON2 P02 | TWI3-SDA | PI1 | |
CON2 P03 | IPSOUT\(5V output\) | ||
CON2 P04 | TWI3-SCK | PI0 | |
CON2 P05 | GND | ||
CON2 P06 | LCD0-IO0 | PH7 | |
CON2 P07 | LCDIO-03 | PH12 | |
CON2 P08 | LCD0-IO1 | PH8 | |
CON2 P09 | LCD0-D0 | LVDS0-VP0 | PD0 |
CON2 P10 | PWM0 | PB2 | |
CON2 P11 | LCD0-D1 | LVDS0-VN0 | PD1 |
CON2 P12 | LCD0-IO2 | ||
CON2 P13 | LCD0-D2 | LVDS0-VP1 | PD2 |
CON2 P14 | LCD0-DE | PD25 | |
CON2 P15 | LCD0-D3 | LVDS0-VN1 | PD3 |
CON2 P16 | LCD0-VSYNC | PD27 | |
CON2 P17 | LCD0-D4 | LVDS0-VP2 | PD4 |
CON2 P18 | LCD0-HSYNC | PD26 | |
CON2 P19 | LCD0-D5 | LVDS0-VN2 | PD5 |
CON2 P20 | LCD0-CS | ||
CON2 P21 | LCD0-D6 | LVDS0-VPC | PD6 |
CON2 P22 | LCD0-CLK | PD24 | |
CON2 P23 | LCD0-D7 | LVDS0-VNC | PD7 |
CON2 P24 | GND | ||
CON2 P25 | LCD0-D8 | LVDS0-VP3 | PD8 |
CON2 P26 | LCD0-D23 | PD23 | |
CON2 P27 | LCD0-D9 | LVDS0-VN3 | PD9 |
CON2 P28 | LCD0-D22 | PD22 | |
CON2 P29 | LCD0-D10 | PD10 | |
CON2 P30 | LCD0-D21 | PD21 | |
CON2 P31 | LCD0-D11 | PD11 | |
CON2 P32 | LCD0-D20 | PD20 | |
CON2 P33 | LCD0-D12 | PD12 | |
CON2 P34 | LCD0-D19 | PD19 | |
CON2 P35 | LCD0-D13 | PD13 | |
CON2 P36 | LCD0-D18 | PD18 | |
CON2 P37 | LCD0-D14 | PD14 | |
CON2 P38 | LCD0-D17 | PD17 | |
CON2 P39 | LCD0-D15 | PD15 | |
CON2 P40 | LCD0-D16 | PD16 |
UART debug PIN of Banana pi BPI-M1+ | |||
Pin Name | Default Function | GPIO | |
CON4 P03 | UART0-TXD | PB22 | |
CON4 P02 | UART0-RXD | PB23 | |
CON4 P01 | GND |
- Android 4.4 source code
- BPI-M1+ DXF file download link : google drive
- BPI-M1+ 3D design file download link :google drive
- Allwinner documents:
Android 4.4
- 2018-07-28 update android 4.4 HDMI version image
Armbian image
- Image lownload link :https://www.armbian.com/banana-pi-plus/
Officeal OpenWRT
BPI BSP for OpenWRT
FreeBSD
OpenSuse
OpenMediaVault
Arch Linux
Gentoo Linux
RaspBSD
CentOS
DietPi
FreeBSD/NetBSD
Lakka TV
- Banana Pi M2+ with H3 chip
- Banana Pi M3 with A83T chip
Simplenas
