香蕉派 BPI-M1
Revision as of 09:26, 25 October 2018 by Sinovoip (talk | contribs) (介绍)
BPI-M1 3D
BPI-M1 with plastic case
BPI-M1/M1+ for BPI 4.0 Successful case :3G Information security terminal
BPI-M1/M1+ for BPI 4.0 Successful case :4G Industrial safety tablets
香蕉派 BPI-M1是一种商用卡片大小和低功耗的单板计算机,具有高性能全志A20双核处理器(1ghz)、1gb DDR3 SDRAM、千兆以太网、SATA、USB和HDMI连接。它可以运行多种操作系统,包括Android, Lubuntu, Ubuntu, Debian和Raspbian。
香蕉派 BPI-M1是香蕉派团队推出的第一款开源硬件,也是香蕉派累积销量最多的一款经典产品。现在还有很多商业客户应用在各种项目上。
  • 全志A20 Dual-core 1.0GHz CPU(A40i芯片可选)
  • 1 GB DDR3 memory.
  • 1x SATA interface.
  • 1x Gigabit LAN
  • 1x USB otg and 2x USB 2.0
  • 1X MIC
  • AV vide out
  • HDMI out
  • IR
  • CSI camera interface
  • DSI display interface
  • 26 PIN gpio
开始使用
硬件接口示意
Banana Pi BPI-M1硬件规格
CPU A20 ARM Cortex -A7 Dual-Core (option:allwinner A40i)
Memory 1GB DDR3
LED Power Key & 8P8C
Storage SATA 2.0,
GPIO PIN 定义
CSI GPIO Pin Pin Name GPIO
CON1 P01 LINEINL
CON1 P02 LINEINR
CON1 P03 VCC-CSI
CON1 P04 ADC\_X1
CON1 P05 GND
CON1 P06 ADC\_X2
CON1 P07 FMINL
CON1 P08 ADC\_Y1
CON1 P09 FMINR
CON1 P10 ADC\_Y2
CON1 P11 GND
CON1 P12 CSI-FLASH PH17
CON1 P13 LRADC0
CON1 P14 TWI1-SDA PB19
CON1 P15 LRADC1
CON1 P16 TWI1-SCK PB18
CON1 P17 CSI-D0 PE4
CON1 P18 CSI0-STBY-EN PH19
CON1 P19 CSI0-D1 PE5
CON1 P20 CSI-PCLK PE0
CON1 P21 CSI-D2 PE6
CON1 P22 CSI0-PWR-EN PH16
CON1 P23 CSI-D3 PE7
CON1 P24 CSI0-MCLK PE1
CON1 P25 CSI-D4 PE8
CON1 P26 CSI0-RESET\# PH14
CON1 P27 CSI-D5 PE9
CON1 P28 CSI-VSYNC PE3
CON1 P29 CSI-D6 PE10
CON1 P30 CSI-HSYNC PE2
CON1 P31 CSI-D7 PE11
CON1 P32 CSI1-STBY-EN PH18
CON1 P33 RESET\#
CON1 P34 CSI1-RESET\# PH13
CON1 P35 CSI-IO0 PH11
CON1 P36 HPR
CON1 P37 HPL
CON1 P38 IPSOUT
CON1 P39 GND
CON1 P40 IPSOUT
LVDS GPIO of Banana pi BPI-M1
Multi 1 Multi 2
CON2 P01 IPSOUT\(5V output\)
CON2 P02 TWI3-SDA PI1
CON2 P03 IPSOUT\(5V output\)
CON2 P04 TWI3-SCK PI0
CON2 P05 GND
CON2 P06 LCD0-IO0 PH7
CON2 P07 LCDIO-03 PH12
CON2 P08 LCD0-IO1 PH8
CON2 P10 PWM0 PB2
CON2 P12 LCD0-IO2 PH9
CON2 P14 LCD0-DE PD25
CON2 P16 LCD0-VSYNC
CON2 P18 LCD0-HSYNC
CON2 P20 LCD0-CS
CON2 P22 LCD0-CLK PD24
CON2 P24 GND
CON2 P26 LCD0-D23 PD23
CON2 P28 LCD0-D22 PD22
CON2 P29 LCD0-D10 PD10
CON2 P30 LCD0-D21 PD21
CON2 P31 LCD0-D11 PD11
CON2 P32 LCD0-D20 PD20
CON2 P33 LCD0-D12 PD12
CON2 P34 LCD0-D19 PD19
CON2 P35 LCD0-D13 PD13
CON2 P36 LCD0-D18 PD18
CON2 P37 LCD0-D14 PD14
CON2 P38 LCD0-D17 PD17
CON2 P39 LCD0-D15 PD15
CON2 P40 LCD0-D16 PD16
Multi 1 Multi 2
J11 Pin1 TXD UART0-TX PB22
J11 Pin2 RXD UART0-RX PB23
Multi 1 Multi 2
J12 Pin1 5V
J12 Pin2 3.3V
J12 Pin3 NC IO-7 PH5
J12 Pin4 RXD UART7\_RX PI21
J12 Pin5 NC IO-8 PH3
J12 Pin6 TXD UART7\_TX PI20
J12 Pin7 GND
J12 Pin8 GND
All GPIO define list:
资源
软件源代码
参考文档
系统镜像
Android 4.4
  • Release Date: 2018-07-26
Baidu Drive: https://pan.baidu.com/s/1HErsANQ4PsnwQJ-tH0AdTg
Google Drive:
Ubuntu Server
  • 2018-7-28 update :Ubuntu Server16.04 HDMI Version Image Link:
Baidu Drive: https://pan.baidu.com/s/1GYH8oDK3T_WcUFn-0t9YmQ
Google Drive: https://drive.google.com/open?id=13XTvWe90yvRdqNWiKCLZ0HcMgo33y2r6
Baidu Drive: https://pan.baidu.com/s/1Tw_99XBZVOmKyavNxCXv3w
Google Drive:
Armbian image
Officeal OpenWRT
BPI BSP for OpenWRT
FreeBSD
OpenSuse
OpenMediaVault
Arch Linux
Gentoo Linux
RaspBSD
CentOS
DietPi
FreeBSD/NetBSD
Lakka TV
Simplenas
