Banana Pi Single board computer Comparison
module
Banana Pi BPI-M1
Banana Pi BPI-M1+
Banana Pi BPI-M2+
Banana Pi BPI-ZERO
Banana Pi BPI-P2 Zero
Banana Pi BPI-M2M
Banana Pi BPI-M2 Berry
Banana Pi BPI-M2U
Banana Pi BPI-M3
Banana Pi BPI-M64
Banana Pi BPI-S64 Core
Banana Pi BPI-F2
Allwinner A20
Allwnner A20
Awinner H3/H2+/H5
Allwinner H2+ same size as RPI Zero W
Allwinner H2+ PoE
Allwinner R16/A33
Allwinner R40/V40 same size as RPI 3
Allwinner R40/V40
Allwinner A83T
Allwinner A64
BPI-S64 Core Actions S700
BPI-F2 with freescale IMX6
in progress
CPU
A20,32 Bit Cortex™-A7 Dual-Core
H3,32 Bit Cortex™-A7 Quad-Core
H2+,32 Bit Cortex™-A7 Quad-Core
A33/R16,32 Bit Cortex™-A7 Quad-Core
R40/V40,32 Bit Cortex™-A7 Quad-Core
A83T,32 Bit Cortex™-A7 Octa-Core
A64, 64 Bit Cortex A53 Quad Core
Actions SOC S700,ARM Cortex-A53 Quad-Core CPU
freescale IMX6 ARM Cortex-A9 MPCore 4xCPU processor(with TrustZone)
GPU
ARM® Mali400MP2
ARM® Mali400MP2
ARM® Mali400MP2
ARM® Mali400MP2
ARM® Mali400MP2
ARM® Mali400MP2
ARM® Mali400MP2
ARM® Mali400MP2
PowerVR SGX544MP2 GPU
ARM® Mali400MP2
Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5
OpenGL ES 2.0 3D graphics accelerator with forshaders,2D graphics accelerator,and didicated OpenVG 1.1 accelerator
Memory \(SDRAM\)
1G (shared with GPU)
512M(shared with GPU)
512(shared with GPU)
2G (shared with GPU)
2GB LPDDR3
2GB LPDDR3
Onboard Storage
SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC
MicroSD(TF) card /MMC card slot eMMC 8GB
MicroSD(TF) card /MMC card slot eMMC 8GB(option)
MicroSD (TF) card / MMC card slot eMMC 8GB SATA 2.0 port via USB
MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC
MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC eMMC 8GB
eMMC8GB
MicroSD (TF) card / MMC card slot ,eMMC 8GB,SATA interface
Network
10/100/1000 Ethernet
NOPE
100M Ethernet
NOPE
Kit:10/100/1000 Ethernet
10/100/1000 Mbit/s Ethernet
Onboard WIFI &BT
NOPE
802.11b/g/n
802.11b/g/n & BT4.0
802.11b/g/n & BT4.0
802.11b/g/n & BT4.0
802.11b/g/n & BT4.0
802.11b/g/n & BT4.0
802.11b/g/n & BT4.0
802.11b/g/n & BT4.0
802.11b/g/n & BT4.0
Kit:802.11b/g/n & BT4.0
N/A
Display
HDMI, CVBS , LVDS/RGB
HDMI
mini HDMI
mini HDMI
MIPI/LVDS
HDMI, MIPI
HDMI, MIPI
HDMI, MIPI
HDMI, MIPI
Kit: HDMI MIPI LVDS
HDMI out, LVDS out
Camera
Parallel 8-bit camera interface
Parallel 8-bit camera interface MIPI Camera serial Interface(CSI)
Kit: DVP camera ;MIPI camera
1 * DVP camera interface and 1* MIP camera interface
Video Outputs
HDMI 1.4@1920*1080P LVDS/Sync RGB/CPU LCD interface up to 1920x1200 Video decoding speed up to 1080p@60fps Video encoding H.264 HP up to 1080p@30fps
HDMI 1.4 1080p@60fps Support H.265 decode by 4K@30fps, support H.264 video encoding up to 1080p@30fps
HDMI 1.4 1080p@60fps,Support H.264 video encoding up to 1080p@30fps
Decoding up to 1920x1080@60fps H.264 HP video encoding up to 1920x1080@60fps
HDMI 1.4 1080p@60fps MIPI LCD interface up to 1920x1080 Decoding up to 1920x1080@60fps Video encoding H.264 HP: speed up 1920x1080@30fps
HDMI 1.4 HEVC/H.265 decoder(SW), Main profile, 1080p@30fps H.264 video encoding up to 1080p@60fps, 720p@120fps
HDMI 1.4 Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,H.265 decode up to 4KP30
support Real-time vide decode of most popular vide formats ,such as MPEG-4,H.264,H.265. support video encoder for baseline H.264
HDMI out, LVDS out
Audio Output
3.5 mm Jack and HDMI
HDMI
mini HDMI
mini HDMI
4ohm/2.5W Speaker(2 Pin Hole)
Kit: 3.5mm Jack and HDMI
1 * 3.5 headset jack,HDMI
Audino In
Microphone
Microphone
NOPE
Microphone
Microphone
Microphone
Microphone
Microphone
Microphone
Microphone
kit:Microphone
Microphone
GPIO
26-PIN: GPIO, UART, I²C bus, SPI bus with two chip selects, CAN bus,PWM,+3.3 V, +5 V, ground
40-PIN: GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground.
Kit: 26-PIN GPIO, UART, I²C bus, SPI bus with two chip selects, PWM,+3.3 V, +5 V, ground
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. CAN bus
Remote
IR reciever
IR reciever
IR reciever
NOPE
NOPE
NOPE
IR reciever
IR reciever
IR reciever
IR reciever
Kit: IR
N/A
USB 2.0 Ports
2 USB ports, 1 OTG microUSB port
1 USB 2.0 OTG
1 USB 2.0 OTG
1 USB 2.0 ports, 1 OTG microUSB port
4 USB ports, 1 OTG microUSB port
Kit:1 USB ports, 1 OTG microUSB port
2 * USB 2.0 1* USB Otg
Buttons
Reset button, Power button, Uboot button
Kit: Reset button, Power button, ADC button
Power & Reset
LED
Power LED (red), RJ45 LED (blue), user define LED (green)
Power LED (red,Can be defined by user)
Power led Status led
User define LED (red/power, blue, green)
Kit: User define LED (red/power, blue, green)
3* RGB leds
Power
5V/2A via MicroUSB and/or MicroUSB (OTG)
5V/2A via DC in and/or MicroUSB (OTG)
5V/2A via MicroUSB
5V/2A via MicroUSB and PoE power
5V/2Avia MicroUSB and/or MicroUSB (OTG)
Kit:DC 5V/2A
12V/2A with DC port
Board Size
92mm×60mm
92mm×60mm
65mm×65mm
65mm×30mm
65mmX52.5mm
51mm×51mm
85mm x 55mm
92mm×60mm
92mm×60mm
92mm×60mm
67.5 x 30 mm
