BPI-Bit
- Buzzer: GPIO25
硬件简介
硬件接口
PIN definitions
| P8 | GPIO16 | ||||
| P9 | GPIO17 | ||||
| P13 | GPIO18 | SPI_SS | |||
| 3V3 | POWER:3V3 | ||||
| GND | GROUND | ||||
| GND | GROUND | ||||
| GND | GROUND | ||||
5*5 25全彩LED灯
| 20 | 15 | 10 | 5 | 0 |
| 21 | 16 | 11 | 6 | 1 |
| 22 | 17 | 12 | 7 | 2 |
| 23 | 18 | 13 | 8 | 3 |
| 24 | 19 | 14 | 9 | 4 |
MPU9250 9-axis sensor
BPI:bit 供电
BPI:bit VS micro:bit
软件
BPI:bit 软件开发规划表与支持应用:
Webduino 软件支持
What is Webduino
BPI:bit Webduino 开发
如何使用 :Use BPI:bit with webduino
webduino 参考教程
Arduino 开发
测试例程
MicroPyhton 开发
Scratch
Github
Useful links
- BPI:bit schematic diagram
- BPI:bit user manual
- BPI:bit dxf file
- ESP32 datasheet
- Espressif ESP32 Resources
- MPU9250 datasheet
- More others
- Webduino official website
- Webduino website in China
- Facebook group
- Maker Pro
