Successful case
Revision as of 10:40, 11 October 2018 by JackZengWiki (talk | contribs) (Undo revision 4695 by Sinovoip (talk))
MT7623N for 4G 路由
A64 智能家居(IoT)网关
4 USB接口4G模块4端口
A83T Raid Nas design
R40 智能车牌识别终端
R40 IoT网关Z-wave, zigbee,WiFI支持
A64 工业用IoT控制网关
A20 多媒体路由网关
H3 for Network security information analysis instrument
A20 for Unmanned aerial vehicle (uav) flight control
T3 design for vehicle traveling data recorderl
File:BPI07402 poe 1.JPG
4G 多路聚合网关
我们做的工作 : 硬件设计, BSP 软件开发,模具开发, 产测程序开发, 批量生产, 产品认证
多路聚合网关基于BPI-R2开发, 支持4 个 4G 模块. 提供多路聚合整体解决方案
4G 多路聚合网关服务器端
4G 多路聚合网关客户端
MultiQB 家庭多媒体网关
what we do : hardware design, BSP software design, tooling design, quantity production, product certification
pcba 硬件:
外壳设计:
  • SIZE: two-deck, 88x88 mm
  • Memory: 1 GB DDR3
  • USB: USB Host 2.0 x 1
  • AUDIO Input: Microphone x 1
  • VIDEO Outputs: HDMI out x 1
  • IR Receiver: x1
  • easy to add zigbee, z-wave ,NB-IoT and other IoT function.
KANO Pixel STEAM 教育套装
我们的服务: 硬件设计, 批量生产
KANO STEAM 教育套装,配合KANO专有的Scratch教育平台,专注在教育领域。
eBlocker VPN安全网关
我们的服务 : 硬件设计, BSP 软件开发, PCBA 硬件提供, 产品认证
3G 信息安全终端
PCBA inside:
4G 工业应用平板
What we do : hardware design, BSP software design, tooling design, quantity production, product certification
PCBA inside:
MTK MT6737 4G 手表
4G watch PCBA:
4G watch Spec
Interface Configuration:
Software Configuration:
Necessary Accessories:
