Banana Pi BPI-M64
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
- Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
- 2 GB DDR3 SDRAM
- 8G EMMC
- 10/100/1000Mbps Ethernet
- WiFi (AP6212) & Bluetooth
Banana Pi M64 | |
CPU | Allwinner A64 64 bit Quad Core ARM Cortex A53 1.2 GHz CPU |
GPU | Dual core Mali 400 MP2 GPU |
Memory | 2 GB LPDDR3 (shared with GPU) |
Storage | MicroSD slot supports up to 256GB expansion & 8 G eMMC flash (option 16/32/64G) |
Network | 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth BT4.0 |
Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
Video Output(s) | high-definition video playback & 2K HDMI port and multi-channel audio output (NO H./X.265 capabilities) |
Audio Input(s) | On board microphone |
Audio Output(s) | 3.5mm jack and HDMI |
USB ports | USB 2.0 PORT (x2), USB OTG (x1) |
Remote | IR Receiver (x1) |
Switches | Reset, Power and U-boot |
LED | Power Status and 8P8C |
Size & Weight | 92x60mm, 48g |
OS | Android and Linux |
Opnewrt
TinaLinux
