Banana Pi BPI-M3
- Allwinner A83T Octa-core 1.8GHz Powerful CPU.
- 2 GB LPDDR3 memory.
- 8 GB eMMC storage.
- HDMI out
- IR control
- WiFi & Bluetooth onboard.
- MIPI DSI ingerface
- CSI camera interface
Banana Pi BPI-M3 | |
CPU | Allwinner A83T ARM Cortex-A7 Octa-Core 1.8 GHz, 512KB L1 cache and 1MB L2 cache |
GPU | PowerVR SGX544MP1 Comply with OpenGL ES 2.0 OpenCL 1x, DX9_3 |
Memory | 2 GB LPDDR3 (shared with GPU) |
Storage | On Board 8GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port (USB-to-SATA bridge) |
Network | 10/100/1000 Mbit/s Ethernet (Realtek RTL8211E/D) + Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0 |
Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
Video Output(s) | HDMI 1.4 (Type A Full), MIPI Display Serial Interface (DSI) for raw LCD Panel |
Audio Input(s) | On board microphone |
Audio Output(s) | 3.5mm jack and HDMI |
USB ports | USB 2.0 PORT (x2), USB OTG (x1) |
Remote | IR Receiver (x1) |
Switches | Reset, Power and U-boot |
LED | Power Status and 8P8C |
Size & Weight | 92x60mm, 48g |
OS | Android and Linux |
40 PIN GPIO define of Banana pi BPI-M3 | |||
Default Function | Function2:GPIO | Function3 | |
CON1-P01 | VCC-3V3 | ||
CON1-P02 | DCIN | ||
CON1-P03 | TWI2-SDA | PH5-EINT5 | |
CON1-P04 | DCIN | ||
CON1-P05 | PH4-EINT4 | ||
CON1-P06 | GND | ||
CON1-P07 | S-PWM | PL10-S-EINT10 | |
CON1-P08 | UART2-TX | PB0-EINT0 | |
CON1-P09 | GND | ||
CON1-P10 | UART2-RX | PB1-EINT1 | |
CON1-P11 | PC4 PC4 | ||
CON1-P12 | UART2-CTS | PB3-EINT3 | |
CON1-P13 | PC7 | PC7 | |
CON1-P14 | GND | ||
CON1-P15 | PC17 | PC17 | |
CON1-P16 | UART2-RTS | PB2-EINT2 | |
CON1-P17 | VCC-3V3 | ||
CON1-P18 | PL8-ENT8 | PL8-S-ENT8 | |
CON1-P19 | SPI0_MOSI | PC0 | |
CON1-P20 | GND | ||
CON1-P21 | SPI0_MISO | PC1 | |
CON1-P22 | PL9-EINT9 | PL9-S-EINT9 | |
CON1-P23 | SPI0_CLK | PC2 | |
CON1-P24 | SPI0_CS | PC3 | |
CON1-P25 | GND | ||
CON1-P26 | PH10-ENT10 | PH10-ENT10 | |
CON1-P27 | TWI1-SDA | PH3-EINT3 | |
CON1-P28 | TWI1-SCK | PH2-EINT2 | |
CON1-P29 | PC18 | PC18 | |
CON1-P30 | GND | ||
CON1-P31 | I2S1-BCLK | PG10-EINT10 | UART3-TX |
CON1-P32 | I2S1-DIN | PG13-EINT13 | UART3-CTS |
CON1-P33 | I2S1-LRCK | PG11-EINT11 | UART3-RX |
CON1-P34 | GND | ||
CON1-P35 | I2S1-DOUT | PG12-EINT12 | UART3-RTS |
CON1-P36 | PE5 | PE5 | |
CON1-P37 | PE4 | PE4 | |
CON1-P38 | OWA-DOUT | PE18 | |
CON1-P39 | GND | ||
CON1-P40 | PE19 | PE19 |
- CSI Camera Connector specification:**
CSI Camera Connector:
CSI camera GPIO of Banana pi BPI-M3 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Default Function| Function2:GPIO| | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
IPSOUT | AFVCC | IPSOUT | IOVDD | GND | GND | CSI2-D3N | AVDD-CSI | CSI2-D3P | DVDD-CSI-R | GND | NC | CSI2-D2N | CSI-RST-R| PE16| | CSI2-D2P | CSI-STBY-R| PE17| | GND | CSI-PCLK| PE0| | CSI2-CKN | CSI-MCLK| PE1| | CSI2-CKP | CSI-HSYNC| PE2| | GND | CSI-VSYNC| PE3| | CSI2-D1N| | CSI-D9| PE13| | CSI2-D1P | CSI-D8| PE12| | GND | CSI-D7| PE11| | CSI2-D0N | CSI-D6| PE10| | CSI2-D0P | CSI-D5| PE9| | GND | CSI-D4| PE8| | CSI-SCK| PE14| | CSI-D3| PE7| | CSI-SDA| PE15| | CSI-D2| PE6| |
- Display specification**
MIPI DSI PIN define of Banana pi BPI-M3 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Default Function| Function2:GPIO| | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
VCC-MIPI | IPSOUT | VCC-MIPI | IPSOUT | GND | IPSOUT | GND | IPSOUT | NC | GND | NC | DSI-D0N | NC | DSI-D0P | NC | GND | TWI0-SDA| PH1-EINT1| | DSI-D1N | TWI0-SCK| PH0-EINT0| | DSI-D1P | TP-INT| PL7-S-EINT7| | GND | TP-RST| PL6-S-EINT6| | DSI-CKN | GND | DSI-CKP | LCD-BL-EN| PD29| | GND | LCD-RST| PD26| | DSI-D2N | LCD-PWR-EN| PD27| | DSI-D2P | GND | GND | LCD-PWM| PD28| | DSI-D3N | GND | DSI-D3P | AP-RESET# | GND |
- UART specification:**
Uart debug pin of Banana pi BPI-M3 | |||
Default Function| GPIO| | |||
UART0-TXD| PB9| | UART0-RXD| PB10| | GND |
