Banana Pi BPI-M3
  • Allwinner A83T Octa-core 1.8GHz Powerful CPU.
  • 2 GB LPDDR3 memory.
  • 8 GB eMMC storage.
  • HDMI out
  • IR control
  • WiFi & Bluetooth onboard.
  • MIPI DSI ingerface
  • CSI camera interface
Banana Pi BPI-M3
Remote IR Receiver (x1)
LED Power Status and 8P8C
Size & Weight 92x60mm, 48g
OS Android and Linux
40 PIN GPIO define of Banana pi BPI-M3
Default Function| Function2:GPIO| Function3| -- | VCC-3V3 DCIN TWI2-SDA| PH5-EINT5 DCIN   TWI2-SCK| PH4-EINT4 GND S-PWM| PL10-S-EINT10 UART2-TX| PB0-EINT0 GND UART2-RX| PB1-EINT1 PC4 PC4 UART2-CTS| PB3-EINT3 PC7| PC7 GND PC17| PC17 UART2-RTS| PB2-EINT2 VCC-3V3 PL8-ENT8| PL8-S-ENT8 SPI0_MOSI| PC0 GND SPI0_MISO| PC1 PL9-EINT9| PL9-S-EINT9 SPI0_CLK| PC2 SPI0_CS| PC3 GND PH10-ENT10| PH10-ENT10 TWI1-SDA| PH3-EINT3 TWI1-SCK| PH2-EINT2 PC18| PC18 GND I2S1-BCLK| PG10-EINT10| UART3-TX| I2S1-DIN| PG13-EINT13| UART3-CTS| I2S1-LRCK| PG11-EINT11| UART3-RX| GND I2S1-DOUT| PG12-EINT12| UART3-RTS| PE5| PE5 PE4| PE4 OWA-DOUT| PE18 GND PE19| PE19
    • CSI Camera Connector specification:**
CSI Camera Connector:
IPSOUT AFVCC IPSOUT IOVDD GND GND CSI2-D3N AVDD-CSI CSI2-D3P DVDD-CSI-R GND NC CSI2-D2N CSI-RST-R| PE16| CSI2-D2P CSI-STBY-R| PE17| GND CSI-PCLK| PE0| CSI2-CKN CSI-MCLK| PE1| CSI2-CKP CSI-HSYNC| PE2| GND CSI-VSYNC| PE3| CSI2-D1N| CSI-D9| PE13| CSI2-D1P CSI-D8| PE12| GND CSI-D7| PE11| CSI2-D0N CSI-D6| PE10| CSI2-D0P CSI-D5| PE9| GND CSI-D4| PE8| CSI-SCK| PE14| CSI-D3| PE7| CSI-SDA| PE15| CSI-D2| PE6|
    • Display specification**
VCC-MIPI IPSOUT VCC-MIPI IPSOUT GND IPSOUT GND IPSOUT NC GND NC DSI-D0N NC DSI-D0P NC GND TWI0-SDA| PH1-EINT1| DSI-D1N TWI0-SCK| PH0-EINT0| DSI-D1P TP-INT| PL7-S-EINT7| GND TP-RST| PL6-S-EINT6| DSI-CKN GND DSI-CKP LCD-BL-EN| PD29| GND LCD-RST| PD26| DSI-D2N LCD-PWR-EN| PD27| DSI-D2P GND GND LCD-PWM| PD28| DSI-D3N GND DSI-D3P AP-RESET# GND
    • UART specification:**
Default Function| GPIO|
UART0-TXD| PB9| UART0-RXD| PB10| GND
Opnewrt
TinaLinux
Release
