BPI-Bit
Revision as of 08:18, 14 September 2018 by legacy>Jh (MicroPyhton)
Overview: BPI:bit
BPI-UNO32 with ESP32 design
Overview: BPI:bit
BPI:bit gpio expansion board
  • Buzzer: GPIO25
Description
Interface
Edge interface
PIN definitions
P3 ADC2_CH4 GPIO13
P0 ADC2_CH8 DAC_1 GPIO25
P4 ADC2_CH3 GPIO16
P5 ADC1_CH7 GPIO35
P6 ADC2_CH5 GPIO12
P7 ADC2_CH6 GPIO14
P1 ADC1_CH4 GPIO32
P8 GPIO16
P9 GPIO17
P10 ADC2_CH9 DAC_2 GPIO26
P11 ADC2_CH7 GPIO27
P12 ADC2_CH2 GPIO02
P2 ADC1_CH5 GPIO33
P13 GPIO18 SPI_SS
P14 GPIO19 SPI_SCK
P15 GPIO23 SPI_MISO
P16 GPIO05 SPI_MOSI
3V3 POWER:3V3
3V3 POWER:3V3
3V3 POWER:3V3
P19 GPIO22 I2C_SCL
P20 GPIO21 I2C_SDA
GND GROUND
GND GROUND
GND GROUND
5*5 LED list
25 5*5 LED list of BPI:bit
20 15 10 5 0
21 16 11 6 1
22 17 12 7 2
23 18 13 8 3
24 19 14 9 4
MPU9250 9-axis sensor
The 9-axis is the combination of 3 separate triple axis sensors. For more detailed information of this chip, click here MPU 9250 datasheet to view the datasheet.
BPI:bit power
BPI:bit VS micro:bit
bpi:bit VS micro:bit
Module bpi:bit micro:bit
RAM 520 KB 16 KB
ROM 448 KB Unkown
Flash 4096 KB 256 KB
WIFI 802.11 b/g/n/e/i N/A
Buzzer 1x Buzzer N/A
Size 5*5 cm 5*4 cm
BPI:bit planning programming:
Webduino
What is Webduino
How to :Use BPI:bit with webduino
Arduino
Arduino IDE Programing Function Define
Function IO
RGB_LED IO4
RGB_LED_POWER IO2
BUZZER IO25
BOTTON_A IO35
BOTTON_B IO27
TEMPERTURE_SENSOR IO34
MPU9250_AD0 IO0
Communication Protocol
SPI
MISO IO19
MOSI IO23
SCK IO23
SS IO5
I2C
SCL IO22
SDA IO21
Arduino IDE
Arduino IDE Compiled
Platform IO
Platform IO Compiled
MicroPyhton
[1]
Scratch
Examples
MPU9250 sample code
Github
Useful links
webduino See sample
  • BPI:bit Through the photosensitive resistors built into Webduino Bit on the left and right sides, it is easy to determine which side the gesture comes from
  • Using Webduino Bit nine shaft sensor "attitude Angle" + full color dot matrix, simple implementation ~ ^_^ interesting effects
