Banana Pi BPI-M2+
Banana PI BPI-M2+ is the open source hardware platform, use Alliwnner H3 (option H2+ H5 ) chip on board. and mini size only 65mm*5mm,
  • Allwinner H3 Quad-core 1.2GHz Cortex-A7 (option H2+ H5).
  • 1GB DDR3
  • 8GB eMMC onboard
  • WiFi and BlueTooth onboard
  • CSI camera interface
HardWare Specification of Banana Pi M2+(Plus)
Flash 8GB eMMC flash onboard
Network 10/100/1000 Ethernet
Audio Outputs HDMI
LED Power led & Status led
IR IR input on board
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI0-SDA PA12-EINT12
CON2-P04 VCC-5V
CON2-P05 TWI0-SCK PA11-EINT11
CON2-P06 GND
CON2-P07 PWM1 PA6-EINT6
CON2-P09 GND
CON2-P11 UART2-RX PA1-EINT1
CON2-P13 UART2-TX PA0-EINT0
CON2-P14 GND
CON2-P15 UART2-CTS PA3-EINT3
CON2-P17 VCC-3V3
CON2-P18 PC4 PC4
CON2-P19 SPI0-MOSI PC0
CON2-P20 GND
CON2-P21 SPI0-MISO PC1
CON2-P22 UART2-RTS PA2-EINT2
CON2-P23 SPI0-CLK PC2
CON2-P24 SPI0-CS PC3
CON2-P25 GND
CON2-P26 PC7 PC7
CON2-P27 TWI1-SDA PA19-EINT19
CON2-P28 TWI1-SCK PA18-EINT18
CON2-P29 PA7-EINT7 PA7-EINT7
CON2-P30 GND
CON2-P31 PA8-EINT8 PA8-EINT8
CON2-P33 PA9-EINT9 PA9-EINT9
CON2-P34 GND
CON2-P39 GND
    • CSI Camera Connector specification:**
| | CSI Pin Name | Default Function | Function2:GPIO | | :--- | :--- | :--- | :--- | | | CN3-P01 | NC | | | | CN3-P02 | GND | | | | CN3-P03 | CSI0-SDA | PE13 | | | CN3-P04 | CSI0-AVDD | | | | CN3-P05 | CSI0-SCK | PE12 | | | CN3-P06 | CSI0-Reset | PE14 | | | CN3-P07 | CSI0-VSYNC | PE3 | | | CN3-P08 | CSI0-PWDN | PE15 | | | CN3-P09 | CSI0-HSYNC | PE2 | | | CN3-P10 | CSI0-DVDD | | | | CN3-P11 | CSI0-DOVDD | | | | CN3-P12 | CSI0-D7 | PE11 | | | CN3-P13 | CSI0-MCLK | PE1 | | | CN3-P14 | CSI0-D6 | PE10 | | | CN3-P15 | GND | | | | CN3-P16 | CSI0-D5 | PE9 | | | CN3-P17 | CSI0-PCLK | PE0 | | | CN3-P18 | CSI0-D4 | PE8 | | | CN3-P19 | CSI0-D0 | PE4 | | | CN3-P20 | CSI0-D3 | PE7 | | | CN3-P21 | CSI0-D1 | PE5 | | | CN3-P22 | CSI0-D2 | PE6 | | | CN3-P23 | GND | | | CN3-P24 | CSI0-DOVDD | | |
    • UART specification:**
| | CON3 Pin Name | Default Function | GPIO | | :--- | :--- | :--- | :--- | | | CON3 P03 | UART0-TXD | PA4 | | | CON3 P02 | UART0-RXD | PA5 | | CON3 P01 | GND | | |
Opnewrt
TinaLinux
Release
