Lighting the RGB LED
Revision as of 04:03, 28 August 2018 by Hulkwang (talk | contribs) (Created page with "==How to lighting the RGB LED== * Librarys:https://github.com/adafruit/Adafruit_NeoPixel Adafruit_NeoPixel from Adafruit * Download librarys and put it in the libraries...")
  • Download librarys and put it in the libraries folder in the root directory of the Arduino IDE
  • Open Arduino IDE
click 'file'->'Example'->'Adafruit NeoPixel'->'simple' to open the example
We need to change some code,Find the code below in the code
 #define PIN            6
 #define NUMPIXELS      16
change to
 #define PIN            4
 #define NUMPIXELS      25
 #define LED_POWER      2
Then add the following code to void setup()
  pinMode(LED_POWER, OUTPUT);
  digitalWrite(LED_POWER, HIGH);
Compile this program
And download it(Set the serial port and board)
