BPI-Bit
About BPI:bit
The BPI-bit (also referred to as BPI:bit, stylised as webduino:bit) is an ESP32 with Xtensa 32bit LX6 single/dual-core processor based embedded system
BPI:bit hardware
BPI:bit interface:
File:Http://forum.banana-pi.org/uploads/default/optimized/2X/b/b2034b198a95fd0d1b5a11a5061b213d0e9bdec9 1 690x389.JPG
