Banana Pi BPI-M1+
Banana Pi BPI-M1+ upgrade is an open-source single-board computer that adds more connectivity to the classic board. It features the same high performance AllWinner A20 dual-core SoC at 1GHz, 1GB of DDR3 SDRAM, Gigabit Ethernet, SATA, USB, and HDMI connections found in classic BPI-M1+ ; but the Banana Pi M1+ features onboard WiFi g/b/n. The board supports all classic projects and even more because of the onboard WIFi chip. Like its sibling, it can run operating systems including Android, Lubuntu, Ubuntu, Debian, and Raspbian.
The Banana Pi M1+ is our upgraded M1 board. We feel like the onboard WiFi adds a lot more features to the board and makes it more convient for users to set up their linx desktop or router projects. Banana Pi is an open platform device, it is for anyone who wants to play and build with developer technology instead of simply using consumer technology. Backed by our community, starting a project and building servers is fun and rewarding. With a Banana Pi, we want you to explore and experience the world of DIY projects and portable computing. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project.
  • 1 GB DDR3 memory.
  • Wifi &BT support onboard
  • 1x SATA interface.
  • 1x Gigabit LAN
  • 1x USB otg and 2x USB 2.0
  • 1X MIC
  • AV out
  • HDMI out
  • IR
  • CSI camera interface
  • DSI display interface
  • 40 PIN gpio
Banana Pi M1+
Memory 1GB DDR3
Network 10/100/1000 Ethernet
wifi&BT Wifi & BT 4.0 support onboard
Power Source 5V/2A via Micro USB (DC in only) and / or Micro USB OTG
LED Power Key & 8P8C
Storage SATA 2.0
40 PIN GPIO of Banana pi BPI-M1+
GPIO Pin Name Default Function Function2:GPIO
CON3-P01 VCC-3V3
CON3-P02 VCC-DC
CON3-P03 TWI2-SDA PB21
CON3-P04 VCC-DC
CON3-P05 TWI2-SCK PB20
CON3-P06 GND
CON3-P07 PWM1 PI3
CON3-P08 UART3\_TX PH0
CON3-P09 GND
CON3-P10 UART3\_RX PH1
CON3-P11 UART2\_RX PI19
CON3-P12 PH2 PH2
CON3-P13 UART2\_TX PI18
CON3-P14 GND
CON3-P15 UART2\_CTS PI17
CON3-P16 CAN\_TX PH20
CON3-P17 VCC-3V3
CON3-P18 CAN\_RX PH21
CON3-P19 SPI0\_MOSI PI12
CON3-P20 GND
CON3-P21 SPI0\_MISO PI13
CON3-P22 UART2\_RTS PI16
CON3-P23 SPI0\_CLK PI11
CON3-P24 SPI0\_CS0 PI10
CON3-P25 GND
CON3-P26 SPI0\_CS1 PI14
CON3-P27 TWI3-SDA PI1
CON3-P28 TWI3-SCK PI0
CON3-P29 I2S\_MCLK PB5
CON3-P30 GND
CON3-P31 I2S\_BCLK PB6
CON3-P32 I2S\_DI PB12
CON3-P33 I2S\_LRCK PB7
CON3-P34 GND
CON3-P35 I2S\_DO0 PB8
CON3-P36 UART7\_RX PI21
CON3-P37 IR0\_TX PB3
CON3-P38 UART7\_TX PI20
CON3-P39 GND
CON3-P40 SPDIF\_DO PB13
    • CSI Camera Connector specification:**
CSI PIN of Banana pi BPI-M1+
CSI Pin Name Default Function Pin name Function2:GPIO
CON1 P01 LINEINL
CON1 P02 LINEINR
CON1 P03 VCC-CSI
CON1 P04 ADC\_X1
CON1 P05 GND
CON1 P06 ADC\_X2
CON1 P07 FMINL
CON1 P08 ADC\_Y1
CON1 P09 FMINR
CON1 P10 ADC\_Y2
CON1 P11 GND
CON1 P12 CSI-FLASH PH17
CON1 P13 LRADC0
CON1 P14 TWI1-SDA PB19
CON1 P15 LRADC1
CON1 P16 TWI1-SCK PB18
CON1 P17 CSI-D0 PE4
CON1 P18 CSI0-STBY-EN PH19
CON1 P19 CSI0-D1 PE5
CON1 P20 CSI-PCLK PE0
CON1 P21 CSI-D2 PE6
CON1 P22 CSI0-PWR-EN PH16
CON1 P23 CSI-D3 PE7
CON1 P24 CSI0-MCLK PE1
CON1 P25 CSI-D4 PE8
CON1 P26 CSI0-RESET\# PH14
CON1 P27 CSI-D5 PE9
CON1 P28 CSI-VSYNC PE3
CON1 P29 CSI-D6 PE10
CON1 P30 CSI-HSYNC PE2
CON1 P31 CSI-D7 PE11
CON1 P32 CSI1-STBY-EN PH18
CON1 P33 AP-RESET\#
CON1 P34 CSI1-RESET\# PH13
CON1 P35 CSI-IO0 PH11
CON1 P36 HPR
CON1 P37 HPL
CON1 P38
CON1 P39 GND
CON1 P40 IPSOUT
    • LVDS specification**
style Default Function | Function2 | Function3:GPIO | :--- | :--- | :--- | IPSOUT\(5V output\) | | | TWI3-SDA | | PI1 | IPSOUT\(5V output\) | | | TWI3-SCK | | PI0 | GND | | | LCD0-IO0 | | PH7 | LCDIO-03 | | PH12 | LCD0-IO1 | | PH8 | LCD0-D0 | LVDS0-VP0 | PD0 | PWM0 | | PB2 | LCD0-D1 | LVDS0-VN0 | PD1 | LCD0-IO2 | | PH9 | LCD0-D2 | LVDS0-VP1 | PD2 | LCD0-DE | | PD25 | LCD0-D3 | LVDS0-VN1 | PD3 | LCD0-VSYNC | | PD27 | LCD0-D4 | LVDS0-VP2 | PD4 | LCD0-HSYNC | | PD26 | LCD0-D5 | LVDS0-VN2 | PD5 | LCD0-CS | | PH6 | LCD0-D6 | LVDS0-VPC | PD6 | LCD0-CLK | | PD24 | LCD0-D7 | LVDS0-VNC | PD7 | GND | | | LCD0-D8 | LVDS0-VP3 | PD8 | LCD0-D23 | | PD23 | LCD0-D9 | LVDS0-VN3 | PD9 | LCD0-D22 | | PD22 | LCD0-D10 | | PD10 | LCD0-D21 | | PD21 | LCD0-D11 | | PD11 | LCD0-D20 | | PD20 | LCD0-D12 | | PD12 | LCD0-D19 | | PD19 | LCD0-D13 | | PD13 | LCD0-D18 | | PD18 | LCD0-D14 | | PD14 | LCD0-D17 | | PD17 | LCD0-D15 | | PD15 | LCD0-D16 | | PD16 |
    • UART specification:**
style Pin Name | Default Function | GPIO | :--- | :--- | :--- | CON4 P03 | UART0-TXD | PB22 | CON4 P02 | UART0-RXD | PB23 | GND | | |
Release
