Banana Pi BPI-R2
Revision as of 06:30, 24 August 2018 by Sinovoip (talk | contribs) (Summary)
BPI-R2 smart router design
BPI-R2 with acrylic case
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • Mini PCIE interface.
  • support 2 SATA interface
Hardware Revision
Banana Pi R2
GPU Mali 450 MP4 GPU
Memory 2G DDR3 SDRAM
Audio Output(s) HDMI & I2S
Remote IR Receiver (x1)
LED Power Status and 8P8C
BPI-R2 GPIO Pin define
BPI-R2 40 PIN GPIO define:
CON1-P02 VCC-5V
CON1-P03 I2C\_SDA0 GPIO75
CON1-P04 VCC-5V
CON1-P05 I2C\_SCL0 GPIO76
CON1-P07 PWM-003 GPIO206
CON1-P08 UTXD1 GPIO80
CON1-P10 URXD0 GPIO81
CON1-P11 URXD1 GPIO80
CON1-P12 I2S0\_BCK GPIO74
CON1-P13 UTXD0 GPIO79
CON1-P15 PWM-002 GPIO205
CON1-P16 URTS1 GPIO25
CON1-P18 UCTS1 GPIO24
CON1-P19 SPI0\_MO GPIO56
CON1-P21 SPI0\_MI GPIO55
CON1-P22 PCM\_CLK GPIO18
CON1-P23 SPI0\_CK GPIO54
CON1-P24 SPI0\_CSN GPIO53
CON1-P26 PCM\_RX GPIO20
CON1-P27 I2C\_SDA1 GPIO57
CON1-P28 I2C\_SCL1 GPIO58
CON1-P29 PCM\_RST GPIO22
CON1-P31 SPDIF\_OUT GPIO200
CON1-P32 PCM\_TX GPIO21
CON1-P33 I2S0\_MCLK GPIO126
CON1-P35 I2S0\_LRCK GPIO73
CON1-P36 PCM\_SYNC GPIO19
CON1-P37 SPDIF\_IN1 GPIO202
MIPI DSI of Banana pi BPI-R2
CN6-P01 VCC-3V3
CN6-P02 VCC-5V
CN6-P03 VCC-3V3
CN6-P04 VCC-5V
CN6-P05 GND
CN6-P06 VCC-5V
CN6-P07 GND
CN6-P08 VCC-5V
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 DSI\_TE GPIO84
CN6-P16 GND
CN6-P17 I2C\_SDA2 GPIO77
CN6-P18 DSI-D1N
CN6-P19 I2C\_SCL2 GPIO78
CN6-P20 DSI-D1P
CN6-P21 CTP-INT GPIO23
CN6-P22 GND
CN6-P23 CTP-RST GPIO236
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 GPIO28
CN6-P28 GND
CN6-P29 GPIO83
CN6-P30 DSI-D2N
CN6-P31 GPIO204
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCM\_BLPWM GPIO203
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 NC
CN6-P40 GND
CON2 P03 UTXD2
CON2P02 URXD2
CON2P01 GND
MTK 7623N datasheet for development board programming guide
CE,FCC,RoHS
Release
Ubuntu with kernel 4.4
Ubuntu with kernel 4.14
OpenWrt(LEDE)
Centos 7
  • Image Release
  • Image Release
release date :2018-06-17
  • SD-Card images:
  • Discuss on forum :
yocto Linux
