Banana Pi BPI-M1
The BPI-M1 is our first product in our goal of creating an open source devlopment board community. With a Banana Pi, we want you to explore and experience the world of DIY projects and portable computing. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project.
- 1 GB DDR3 memory.
- 1x SATA interface.
- 1x Gigabit LAN
- 1x USB otg and 2x USB 2.0
- 1X MIC
- AV vide out
- HDMI out
- IR
- CSI camera interface
- DSI display interface
- 26 PIN gpio
Banana Pi BPI-M1 | |
CPU | A20 ARM Cortex -A7 Dual-Core |
GPU | ARM Mali 400 MP2; Complies with OpenGL ES 2.0/1.1 |
Memory | 1GB DDR3 |
Network | 10/100/1000 Ethernet 8P8C (1000BASE-T) |
Video Input | A CSI input connector allows for the connection of a designed camera module |
Video Outputs | HDMI, CVBS, LVDS/RGB |
Audio Outputs | 3.5mm jack and HDMI |
Power Source | 5 volts DC via Micro USB or GPIO |
USB 2.0 ports | 2 (direct from Allwinner A20 chip) |
GPIO | GPIO, UART, I2C BUS, SPI BUS, WITH TWO CHIP SELECTS, CAN bus, ADC, PWM, +3.3V, +5V, GND |
LED | Power Key & 8P8C |
Storage | SATA 2.0, |
40 PIN GPIO of Banana pi BPI-M1 | |||
CSI GPIO Pin | Pin Name | GPIO | |
CON1 P01 | LINEINL | ||
CON1 P02 | LINEINR | ||
CON1 P03 | VCC-CSI | ||
CON1 P04 | ADC\_X1 | ||
CON1 P05 | GND | ||
CON1 P06 | ADC\_X2 | ||
CON1 P07 | FMINL | ||
CON1 P08 | ADC\_Y1 | ||
CON1 P09 | FMINR | ||
CON1 P10 | ADC\_Y2 | ||
CON1 P11 | GND | ||
CON1 P12 | CSI-FLASH | PH17 | |
CON1 P13 | LRADC0 | ||
CON1 P14 | TWI1-SDA | PB19 | |
CON1 P15 | LRADC1 | ||
CON1 P16 | TWI1-SCK | PB18 | |
CON1 P17 | CSI-D0 | PE4 | |
CON1 P18 | CSI0-STBY-EN | PH19 | |
CON1 P19 | CSI0-D1 | PE5 | |
CON1 P20 | CSI-PCLK | PE0 | |
CON1 P21 | CSI-D2 | PE6 | |
CON1 P22 | CSI0-PWR-EN | PH16 | |
CON1 P23 | CSI-D3 | PE7 | |
CON1 P24 | CSI0-MCLK | PE1 | |
CON1 P25 | CSI-D4 | PE8 | |
CON1 P26 | CSI0-RESET\# | PH14 | |
CON1 P27 | CSI-D5 | PE9 | |
CON1 P28 | CSI-VSYNC | PE3 | |
CON1 P29 | CSI-D6 | PE10 | |
CON1 P30 | CSI-HSYNC | PE2 | |
CON1 P31 | CSI-D7 | PE11 | |
CON1 P32 | CSI1-STBY-EN | PH18 | |
CON1 P33 | RESET\# | ||
CON1 P34 | CSI1-RESET\# | PH13 | |
CON1 P35 | CSI-IO0 | PH11 | |
CON1 P36 | HPR | ||
CON1 P37 | HPL | ||
CON1 P38 | IPSOUT | ||
CON1 P39 | GND | ||
CON1 P40 | IPSOUT |
LVDS GPIO of Banana pi BPI-M1 | ||||
LVDS Pin | Pin Name | Multiplex Function Select | GPIO | |
Multi 1 | Multi 2 | |||
CON2 P01 | IPSOUT\(5V output\) | |||
CON2 P02 | TWI3-SDA | PI1 | ||
CON2 P03 | IPSOUT\(5V output\) | |||
CON2 P04 | TWI3-SCK | PI0 | ||
CON2 P05 | GND | |||
CON2 P06 | LCD0-IO0 | PH7 | ||
CON2 P07 | LCDIO-03 | PH12 | ||
CON2 P08 | LCD0-IO1 | PH8 | ||
CON2 P09 | LCD0-D0 | LVDS0-VP0 | ||
CON2 P10 | PWM0 | |||
CON2 P11 | LCD0-D1 | LVDS0-VN0 | ||
CON2 P12 | LCD0-IO2 | PH9 | ||
CON2 P13 | LCD0-D2 | LVDS0-VP1 | ||
CON2 P14 | LCD0-DE | PD25 | ||
CON2 P15 | LCD0-D3 | LVDS0-VN1 | ||
CON2 P16 | LCD0-VSYNC | |||
CON2 P17 | LCD0-D4 | LVDS0-VP2 | ||
CON2 P18 | LCD0-HSYNC | |||
CON2 P19 | LCD0-D5 | LVDS0-VN2 | ||
CON2 P20 | LCD0-CS | |||
CON2 P21 | LCD0-D6 | LVDS0-VPC | ||
CON2 P22 | LCD0-CLK | PD24 | ||
CON2 P23 | LCD0-D7 | LVDS0-VNC | ||
CON2 P24 | GND | |||
CON2 P25 | LCD0-D8 | LVDS0-VP3 | ||
CON2 P26 | LCD0-D23 | |||
CON2 P27 | LCD0-D9 | LVDS0-VN3 | ||
CON2 P28 | LCD0-D22 | |||
CON2 P29 | LCD0-D10 | |||
CON2 P30 | LCD0-D21 | |||
CON2 P31 | LCD0-D11 | |||
CON2 P32 | LCD0-D20 | |||
CON2 P33 | LCD0-D12 | |||
CON2 P34 | LCD0-D19 | |||
CON2 P35 | LCD0-D13 | |||
CON2 P36 | LCD0-D18 | |||
CON2 P37 | LCD0-D14 | |||
CON2 P38 | LCD0-D17 | |||
CON2 P39 | LCD0-D15 | |||
CON2 P40 | LCD0-D16 |
- UART specification:**
| J11 Pin | Pin Name | Multiplex Function Select | GPIO | | :--- | :--- | :--- | :--- | | | | Multi 1 | Multi 2 | | J11 Pin1 | TXD | UART0-TX | PB22 | | J11 Pin2 | RXD | UART0-RX | PB23 | |- |}
Jumper J12 of Banana pi BPI-M1 | |||||||||||||
J12 Pin | Pin Name | Multiplex Function Select | GPIO | Multi 2 | | 5V | | | | 3.3V | | | | NC | IO-7 | PH5 | | RXD | UART7\_RX | PI21 | | NC | IO-8 | PH3 | | TXD | UART7\_TX | PI20 | | GND | | | | GND | | | |
